Re: Are Thermoquads interchangable???
[Re: Dusted_Ya]
#673310
04/18/10 12:55 AM
04/18/10 12:55 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
I have found that they are better anchors...
I am truckless..
[Re: twinscrew698]
#673313
04/19/10 01:01 PM
04/19/10 01:01 PM
Posts: 3,424 Portland Oregon
69Dartman
Portland Oregon
The bigger ones should work fine seeing how I think it's only the primary bores that are bigger. As long as nothing hits other then that the carb itself is the same size. It MIGHT be a bit overjetted for your engine, but they are pretty easy to adjust if you understand how they work and what to adjust. I run a aftermarket 9800 800cfm on my 318 with either 92 or 95 jets, the metering rod adjustment has been tweaked just right and I did the air door as well. It has a electric choke with the round dial for adjusting so it's easy to get to run cold and I think the smaller primaries give it a bit better MPG and bottom end grunt.
Life's a little bit better when you hit a Camaro.
[Re: 69Dartman]
#673314
04/19/10 01:13 PM
04/19/10 01:13 PM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
is basically a plug and play job in relation with phisical fitment.
then some diff are in between, cfms, jetting, vacuum tees, linkage adjustments and maybe the most "important"... gas INLET needing to match with your car setup, due some are on rear of the carb instead at a side.
[Re: dOc !]
#673316
04/19/10 02:29 PM
04/19/10 02:29 PM
NachoRT74
Valencia, España
some 318s were factory installed down here in Venezuela with TQs and AVSs
and 70s 340s were TQ factory...( not a GIANT diff )
too much BS about they can't be on a 318s... simply fit, tune and voila!
Down here is a tipical "upgrade" without ANY problem
BTW not a such difference between 400 and 440 carbs beside just the jets and some more tweak, but same bore diameters so same cfms
[Re: 340SHORTY]
#673318
04/19/10 03:00 PM
04/19/10 03:00 PM
Posts: 3,920 n.e. pa.
65rbdodge
n.e. pa.
in my experience i have also found this to be true.
[Re: 65rbdodge]
#673320
04/19/10 04:27 PM
04/19/10 04:27 PM
Posts: 30,474 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
YOU BerriBumz are all the same ...
Berry CRABS are muchO bester anchors ... they weigh a fricken TON.
[Re: dOc !]
#673321
04/20/10 06:09 PM
04/20/10 06:09 PM
69Dartman
Portland Oregon
They just don't understand how they work or how to tune one. I liked the theories of operation behind them and the spreadbore concept in general so I found one, rebuilt it, and loved the way it worked on my 318 so I've stuck with them. I tried a AFB, AVS, and a Holley and it just ran smoother, got more power, and better MPG then anything else I tried. If you get a bad one that's cracked or completely messed up they can horrid, but a good one will make you happy on a street engine.
[Re: dulcich]
#673323
04/20/10 09:06 PM
04/20/10 09:06 PM
Posts: 543 Indiana, Just Off I-70
BradD
And the deep throaty sound when the secondary's kick in is way cool!!
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
[Re: 69Dartman]
#673324
04/20/10 09:42 PM
04/20/10 09:42 PM
Posts: 1,061 New Mexico
dmerc
New Mexico
Yup!! Dial in a thermoquad and you'll never look back. Ive tried them all.
