ARP Moly lube #672657
04/17/10 04:20 PM
04/17/10 04:20 PM
Long Island, NY.
Stroked65Belv Offline OP
Long Island, NY.
If the ARP preferred moly lube isnt available, and you use regular oil. What do you guys do for torque specs? Same as whats called for?
Im installing main studs 90lbs. torqued but have no ARP lube..
Re: ARP Moly lube [Re: Stroked65Belv] #672658
04/17/10 04:31 PM
04/17/10 04:31 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
CRC make an overgrown toothpaste tube of moly, i've been using mine for years. if i remember correctly the torque spec with oil is different than moly. ARP use to have all their torque specs with oil/moly written on the bottom of their head stud box. i kept the box for reference. what size bolt/stud you got?, i could go check the box.
Re: ARP Moly lube [Re: rebel] #672659
04/17/10 04:56 PM
04/17/10 04:56 PM
Long Island, NY.
Long Island, NY.
They are 1/2" main cap studs. Thanks for the help.
Re: ARP Moly lube [Re: Stroked65Belv] #672660
04/17/10 05:11 PM
04/17/10 05:11 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
ok, according to the bottom of the ARP box, if they're 170k studs it's 101/oil 84/moly. if they're 190k studs it's 122/oil 95/moly & if they're 220k studs it's 135/oil 105/moly. hope this helps.
Re: ARP Moly lube [Re: rebel] #672661
04/17/10 07:26 PM
04/17/10 07:26 PM
Brisbane Australia
572B1 Offline
572B1  Offline
Brisbane Australia
hey reb, recheck the torque on the 170k studs,my studs show 108 for oil and 84 for moly. I have the same torque spec on the 190k and the 220k spec as you.
also this is for 30 wt engine oil.
Re: ARP Moly lube [Re: Stroked65Belv] #672662
04/17/10 07:52 PM
04/17/10 07:52 PM
NC
440Jim Offline
440Jim  Offline
NC
Order the same lube as used during machining (align hone, rod hone, etc). Wait until FedEx delivers it. It is available, just wait.
Re: ARP Moly lube [Re: 572B1] #672663
04/17/10 09:16 PM
04/17/10 09:16 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
yeah with close inspection with a magnifying glass they could be 108. since it's on the bottom of the box theres a bit of wear & it's a bit hard to read but you could be right.
Re: ARP Moly lube [Re: Stroked65Belv] #672664
04/18/10 12:52 AM
04/18/10 12:52 AM
Long Island, NY.
Long Island, NY.
Thanks for the helo guys, much appreciated!
