Re: ARP Moly lube
[Re: rebel]
#672661
04/17/10 07:26 PM
04/17/10 07:26 PM
Posts: 855 Brisbane Australia
572B1
Brisbane Australia
ok, according to the bottom of the ARP box, if they're 170k studs it's 101/oil 84/moly. if they're 190k studs it's 122/oil 95/moly & if they're 220k studs it's 135/oil 105/moly. hope this helps.
hey reb, recheck the torque on the 170k studs,my studs show 108 for oil and 84 for moly. I have the same torque spec on the 190k and the 220k spec as you.
also this is for 30 wt engine oil.
Re: ARP Moly lube
[Re: 572B1]
#672663
04/17/10 09:16 PM
04/17/10 09:16 PM
Posts: 4,647 aotearoa
rebel
aotearoa
yeah with close inspection with a magnifying glass they could be 108. since it's on the bottom of the box theres a bit of wear & it's a bit hard to read but you could be right.
