Indy EZ cnc 295 heads, H.S. Rockers, pushrod clearance #672649
04/17/10 03:31 PM
04/17/10 03:31 PM
Central Coast
P
Plumcrazyracing Offline OP
P
Central Coast
Just swapped over to Harland Sharp 1.5 ratio rockers and found that on full lift my pushrods touch the intake runner on the head (top part of intake runner). Unfortunately, i did not check to see how much clearance I had before I took off the Indy rocker set up. I would think i need about .030 clearance.
has anyone experienced this with the EZ heads and Harland Sharp rockers?
Any advice on opening the guide area up?
Thanks,
Steve
Re: Indy EZ cnc 295 heads, H.S. Rockers, pushrod clearance [Re: Plumcrazyracing] #672650
04/17/10 04:01 PM
04/17/10 04:01 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I ran harland 1.7's on my indy cnc'd ez and the shop opened up the pushrod holes for me.... you can do it yourself though
Mopar Performance
