mini starter #672557
04/17/10 01:10 PM
04/17/10 01:10 PM
Ontario,Canada
1967GTX440 Offline OP
Ontario,Canada
I am changing my Steering box and motor&trans mounts and while I am at it thought I would put a new starter on.It's a 440 not stock any thoughts from anyone on the best starter.Are the mini starter good do they last a long time or any other ideas.
Thanks in advance
Re: mini starter [Re: 1967GTX440] #672558
04/17/10 01:23 PM
04/17/10 01:23 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
They rarely die and when they do it is usually a set of low buck contacts that go. They are well worth the money. I get them at a JY and have yet to get a bad one and have changed over quite a few.
Re: mini starter [Re: 1967GTX440] #672559
04/17/10 01:30 PM
04/17/10 01:30 PM
AndyF Offline
AndyF  Offline
Great upgrade for a Mopar engine.
Re: mini starter [Re: AndyF] #672560
04/17/10 01:32 PM
04/17/10 01:32 PM
AndyF Offline
AndyF  Offline
Don't forget a new shield for the mini starter. Mancini Racing has them. They have a different shape to fit the nose of the mini-starter.
Re: mini starter [Re: AndyF] #672561
04/17/10 08:31 PM
04/17/10 08:31 PM
Detroit Michigan
stinger Offline
stinger  Offline
Detroit Michigan
just a word of caution but this starter will not fit between the block and headmen headers,not sure on the other brands.
Re: mini starter [Re: stinger] #672562
04/17/10 09:17 PM
04/17/10 09:17 PM
St.Clairsville Ohio
EV2RUNNER Offline
EV2RUNNER  Offline
St.Clairsville Ohio
Big Block or Small with fitment issue? Mine fit on 383 w/ mini starter.
Re: mini starter [Re: EV2RUNNER] #672563
04/17/10 09:37 PM
04/17/10 09:37 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
mine fit with 440 and mini starter.
Re: mini starter [Re: Dougsmopars] #672564
04/17/10 09:50 PM
04/17/10 09:50 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
my 440source mini starter fit with Hedman 78030's on a 451 (lowdeck), but not without a bit of massaging of one tube with a ball peen hammer and a torch
Re: mini starter [Re: DrCharles] #672565
04/17/10 11:16 PM
04/17/10 11:16 PM
East Central Illinois
jeff57 Offline
jeff57  Offline
67 cars need a little rubbing to get a mini starter in if headers are used. but the mini starter is the way to go. jeff57
Re: mini starter [Re: jeff57] #672566
04/18/10 12:26 AM
04/18/10 12:26 AM
AndyF Offline
AndyF  Offline
Fits just fine with a 3 inch head pipe.
Re: mini starter [Re: stinger] #672567
04/18/10 02:36 AM
04/18/10 02:36 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Junkyard 90's dodge v8 ministarter fit perfect on my 440 with summit brand(rebadged hedman) headers.
Re: mini starter [Re: DrCharles] #672568
04/18/10 12:24 PM
04/18/10 12:24 PM
Detroit Michigan
stinger Offline
stinger  Offline
Detroit Michigan
YEP ^^^^^^^^^^^
I would like to spring for another set but figure what's the point if I have to beat them into submission.
Re: mini starter [Re: stinger] #672569
04/18/10 12:52 PM
04/18/10 12:52 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
YEP ^^^^^^^^^^^
Because they cost one-fifth as much as the "perfect fit" types, which STILL sometimes require a bit of persuasion!
Re: mini starter [Re: DrCharles] #672570
04/18/10 01:40 PM
04/18/10 01:40 PM
Detroit Michigan
stinger Offline
stinger  Offline
Detroit Michigan
car is a '70 cuda with 440/727 with power steering.
Re: mini starter [Re: stinger] #672571
04/18/10 05:20 PM
04/18/10 05:20 PM
scratchnfotraction Offline
now thats tight for a mini starter
heat will deff be a problem in the long haul
Re: mini starter [Re: stinger] #672572
04/18/10 06:03 PM
04/18/10 06:03 PM
MI
Jerseyboy Offline
Jerseyboy  Offline
MI
I just went through this on my 68 Coronet 383 with headman elite headers. I bought a starter for a 94 Dakota 318 and it wouldn't fit. The later model V8 starter (I checked a 2002 dakota V8) has a shorter motor then the earlier one. I probably could have fit the later starter. My local Auto store had them for $129 plus core. The Earlier unit was only $80 plus core. I ended up putting the original back in for now. I'm eventually going with a late model 6.1 based stroker so this is only a temporary setup for me and I decided to save the cash now.
Re: mini starter [Re: stinger] #672573
04/18/10 06:14 PM
04/18/10 06:14 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: mini starter [Re: stinger] #672574
04/18/10 08:32 PM
04/18/10 08:32 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Mine wouldn't work with hedmans either.
Mine looked like Stinger's,I went back to manifolds.
Re: mini starter [Re: pushbutton] #672575
04/19/10 07:26 AM
04/19/10 07:26 AM
Detroit Michigan
stinger Offline
stinger  Offline
Detroit Michigan
what I don't understand is all these people that say they have no problems with the headmen's and the few that do,what gives?
Re: mini starter [Re: stinger] #672576
04/19/10 07:50 AM
04/19/10 07:50 AM
on my SB I have the hedman truck headers and can R&R the starter with out removing the header
I can R&R the header with out removing the starter also
I run the center dump mannys on the 440 and have lots of room
what part# on the headers that are tight like in the pics??
cars only? any trucks this way?
may just be the style of headers and body style together that does this
