GTS or Formula S steering box anything special? #672512
04/17/10 12:34 PM
04/17/10 12:34 PM
Pennsylvania
craigerlitz Offline OP
Pennsylvania
Just wondering if a manual steering box out of a GTS or Formula S car has a different ratio than a /6 Dart or Barracuda.
Thanks,
Craig
Re: GTS or Formula S steering box anything special? [Re: craigerlitz] #672513
04/17/10 01:45 PM
04/17/10 01:45 PM
AndyF Offline
AndyF  Offline
There was an optional 16:1 manual box. It was an option on A body cars but I don't think it was part of a package deal. But it would probably be more likely to show up on a special order car.
Re: GTS or Formula S steering box anything special? [Re: AndyF] #672514
04/19/10 01:14 PM
04/19/10 01:14 PM
Portland Oregon
69Dartman Offline
69Dartman  Offline
Portland Oregon
My western sport special dart has the 16 to 1 box and 340 suspension WITHOUT a front sway bar. It was a A body only option and I think only available from 66 to 69.
I later added the front sway bar and poly bushings, and a rear sway bar outa a valiant police package car from 76.
I also think all you had to do was check the proper box when ordering any A body in the right years, and most folks did not.
It goes from 6 turns lock to lock to a tiny bit less then 4 and about doubles the effort to turn the wheels but sure handles and feels nice when driving the car.
I never knew my car was a special 16 to 1 till I test drove a /6 69 with the stock box in it and almost hit a pole when I turned it enough to make the turn as if it was my car...
Life's a little bit better when you hit a Camaro.
