72 dart swinger #672415
04/17/10 11:09 AM
04/17/10 11:09 AM
wi
sixpaccornet Offline OP
wi
have a 72 swinger,it had a 74 360 trying to install a 85 318 having a problem with motor mounts what ones do i use thanks six
Re: 72 dart swinger [Re: sixpaccornet] #672416
04/17/10 12:36 PM
04/17/10 12:36 PM
St Paul MN
73swinger Offline
73swinger  Offline
St Paul MN
I think you need pre-spool mount 318 motor mounts if k frame has not been changed.
Chris Schwartz 73 Swinger 340 12.451 @ 108.78 73 Gold Duster, needs a plan.
Re: 72 dart swinger [Re: 73swinger] #672417
04/17/10 01:01 PM
04/17/10 01:01 PM
wi
wi
would those be the mounts from the 85 318
Re: 72 dart swinger [Re: sixpaccornet] #672418
04/17/10 01:37 PM
04/17/10 01:37 PM
Spokane Valley, Washington
stryker63 Offline
stryker63  Offline
Hello,
I would recommend Schumacher Creative Services.
They carry replacment motor mounts for all sorts of Mopar engine swaps - they even have a conversion motor mount kit to drop a V8 in place of a six without changing k-members! Or even drop a big block into an A-Body.
I was seriously considering them until I got a V8 k-member for my '73 Duster.
Check 'em out - www.engine-swaps.com
Re: 72 dart swinger [Re: sixpaccornet] #672419
04/17/10 02:00 PM
04/17/10 02:00 PM
St Paul MN
73swinger Offline
73swinger  Offline
St Paul MN
I'm pretty sure your Dart has the bisquit style motor mounts if k frame is original. (this is the mount that has a stud going down through the k frame) spool mount, like the 85 would have, mounts to k frame with a nut & bolt that goes front to back through U channels on k frame with motor mounts round rubber bushing in between. best I can explain.
in other words there are 2 different k frames (bisquit = pre 73 & spool = 73 up)
273 & 318 share same mounting spots on motor
340 & 360 share same mounting to motor, but different from 273/360.
Identify what k frame you have & we can let you know what mounts to use or get.
Re: 72 dart swinger [Re: 73swinger] #672420
04/17/10 02:56 PM
04/17/10 02:56 PM
wi
wi
its the pre spool mount.has a pad between the motor and k frame not a doughnut in the mount
Re: 72 dart swinger [Re: sixpaccornet] #672421
04/17/10 03:57 PM
04/17/10 03:57 PM
St Paul MN
73swinger Offline
73swinger  Offline
St Paul MN
OK 1 mount off the 360 (I don't remember which side) will work. the other needs to be a 318 pre 73 mount.
at this point I would order new mounts for for a 318 in a 72 dart. Mancini, schumaker, etc.
Re: 72 dart swinger [Re: 73swinger] #672422
04/17/10 04:05 PM
04/17/10 04:05 PM
wi
wi
ok thanks much you saved us slot of headache
Re: 72 dart swinger [Re: sixpaccornet] #672423
04/17/10 04:07 PM
04/17/10 04:07 PM
St Paul MN
73swinger Offline
73swinger  Offline
St Paul MN
where in Wisconsin are you??
Re: 72 dart swinger [Re: 73swinger] #672424
04/17/10 05:00 PM
04/17/10 05:00 PM
wi
wi
in madison its for my sons dart im more of a 66-67 b body guy.its his first car and he is ready to have the motor back in
