Dana 60 vrs 8.75 are axles the same? #671648
04/16/10 06:32 PM
04/16/10 06:32 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline OP
just got a chance at a dana 60 housing..
for free...
will my Mark williams axles from my 8.75 fit/work in it.?
i will be re-sizing the width to the same width as my 8.75..
and will be buying a spool/ gears. and bearings with new housing ends...
can i make these axles work..?
i also assume my billet 1350 pinion yolk will transfer over to the d60 pinion...?
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: Dana 60 vrs 8.75 are axles the same? [Re: cheapstreetdustr] #671649
04/16/10 07:29 PM
04/16/10 07:29 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
From what I remember the dana has one axle 1 3/16 shorter. So if you shorten the rear 2 3/8 or offset the pinion they can work. You would also need to re spline one axle
Re: Dana 60 vrs 8.75 are axles the same? [Re: The Shadow] #671650
04/16/10 07:39 PM
04/16/10 07:39 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I dont know how, but the custom axles in my 65 Plymouth ended up being the same length. The pinion is offset in the case to the passenger side 1-1 1/2 or so??
But the axle length might not be the only thing that can cause problems. The spline pitch on there axles are diff, even though the axle spline count might be the same, it stiff wont work...
Id do some homework on this one, starting with a phone call to mark Williams.
Re: Dana 60 vrs 8.75 are axles the same? [Re: cheapstreetdustr] #671651
04/16/10 08:28 PM
04/16/10 08:28 PM
Locomotion Offline
Locomotion  Offline
Standard Mark Williams spool and axle splines are a different pitch and are not recommended to be mixed with other brands.
Aside from that, as others have stated, axles are the same except for the lengths - unless you cut the housing to match them. My standard 8 3/4 rear has both axles the same length. The Dana 60 in my old Challenger had a 1" difference in axle lengths.
Re: Dana 60 vrs 8.75 are axles the same? [Re: Locomotion] #671652
04/16/10 09:41 PM
04/16/10 09:41 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I used my axles out of my 8 3/4 that were 35 spline. I narrowed the Dana 1" shorter than the 8 3/4. That placed the one axle flush with the inside of the spool splines. The other axle had enough spline to slide deeper into the spool (the end hung inside the spool). Ran it that way 10 years. it's still in the car today.
Doug
Re: Dana 60 vrs 8.75 are axles the same? [Re: cheapstreetdustr] #671653
04/16/10 10:18 PM
04/16/10 10:18 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I used a pair of 8 3/4 35 spline Moser axles in my Dana with a Strange spool with no issues.
Gus
64 Plymouth Savoy
Dana 60
Re: Dana 60 vrs 8.75 are axles the same? [Re: fourgearsavoy] #671654
04/16/10 11:27 PM
04/16/10 11:27 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Gus
hmm I had no idea the Dana60 used the same shafts as the 8.75 with the exception of length issues.
**Photobucket sucks**
Re: Dana 60 vrs 8.75 are axles the same? [Re: 70Cuda383] #671655
04/16/10 11:55 PM
04/16/10 11:55 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Hey Cheap.
The pinion offset is 1 3/16. You make the pass side tube 1 3/8" shorter to get there with a Dana
If you have a Williams axles, get a willaims spool.
You're going to end up 1 3/8" shorter in total to get the axles you have to work with correct pinion offsets. What's that 11/16 shorter on each side once you get the perches installed. You may be able to cheat a bit using a wider air gap spacing in the spool with axle engagement. Sort of like what DVW did on his. See how far the axle engages in the spool.
Send me a PM with your e-mail. I have a pretty cool axle length spreadsheet.
Re: Dana 60 vrs 8.75 are axles the same? [Re: cheapstreetdustr] #671656
04/17/10 12:05 AM
04/17/10 12:05 AM
If your 8 3/4 axles are 35 spline then they can be made to work, I just went through that last fall I shorten the Ford 3/4 ton P.U. Dana 60 one inch narrower than the 8 3/4, 1/2 inch per side. I had to wack about 3/8 inch off the right side axle to make it fit without touching the left axle in the spool, I did have the Dana 60 axle shorten so the Dana 60 pinion ended up in the exact same location as the 8 3/4 pinion center was I also bought the Moser axle ends so I could use a stock inner axle seal to keep the rear end grease from leaking out of the axles onto the brake backing plates and onto the brakes. The green bearing O rings and stock foam axle gaskets would leak and seep some
Re: Dana 60 vrs 8.75 are axles the same? [Re: 70Cuda383] #671657
04/17/10 07:44 AM
04/17/10 07:44 AM
Locomotion Offline
Locomotion  Offline
Gus
Just to clarify, it's only between the same spline counts.
OEM 8 3/4" are normally 30 spline. OEM Dana 60 are normally 23(?) and 35 spline. Aftermarket 35 spline spools and axles are available for 8 3/4's and those axles are basically the same as 35 spline Dana 60 axles, except for length per application. (In car applications.)
Re: Dana 60 vrs 8.75 are axles the same? [Re: Locomotion] #671658
04/17/10 05:25 PM
04/17/10 05:25 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
OEM 8 3/4" axles are always 30 spline and some truck Dana 60's use the same spline. The only way you could use equal length 8 3/4" axles in a Dana 60 would be to use a different pinion offset than Mopar passenger cars use and then the pinion wouldn't line up with the tunnel.
Re: Dana 60 vrs 8.75 are axles the same? [Re: John_Kunkel] #671659
04/17/10 08:03 PM
04/17/10 08:03 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My axles (Strange 35 spline) had enough spline to allow the placement of the axle into the spool on the short tube side. The other side originally placed the end of the axle about 1/2" beyond the inner edge of the spool. The Dana placement was flush with the inside of the spool. The housing had the stock offset.
Doug
Re: Dana 60 vrs 8.75 are axles the same? [Re: dvw] #671660
04/17/10 10:11 PM
04/17/10 10:11 PM
North of Detroit
HemiDart68 Offline
HemiDart68  Offline
North of Detroit
If your rear is B body width, ill make you a really good deal on a set of factory dana axles.
In God we trust, all others pay cash. www.lightnens.com (Home of the world's fastest Paint Job)
Re: Dana 60 vrs 8.75 are axles the same? [Re: HemiDart68] #671661
04/20/10 08:00 PM
04/20/10 08:00 PM
they are 35 spline i think..its a spool now..
i am gonna put the dana housing the same length as my 8.75 so i can keep my rims/tires..
cheapst.
[image][/image]
