Would anyone have a few pictures of the correct routing of the positive batter cable on a 67 Hemi automatic. I would like to see a couple of pictures from under the car showing the cable and how it should lay along the starter.
I am installing a reproduction harness into a car that didn't have an original Hemi cable there, so I'm not sure how it should be.
The new cable has straight ends that connect to the starter that I assume you have to bend at a 90 degree to get them to clear the exhaust manifolds.
Dan
