Harland-Sharp roller rockers vs. OEM #671578
04/16/10 03:49 PM
04/16/10 03:49 PM
Spokane Valley, Washington
stryker63 Offline OP
Greetings,
I am building up a mild 5.2L Magnum for my '73 Duster.
The block is bored 0.30 over and I'm using a hotter cam (216 intake/224 exhaust @ 0.05, 0.506 lift) and will be running the usual bolt-ons (4-bbl and appropriate intake, headers). My horsepower goal is 300+
My question is this - I found a set of Harland-Sharp roller rockers that are a bolt-on replacement for the stock rollers - are they worth the expense?
Any info would be appreciated.
Re: Harland-Sharp roller rockers vs. OEM [Re: stryker63] #671579
04/16/10 04:30 PM
04/16/10 04:30 PM
Spartanburg SC
MoparDan Offline
MoparDan  Offline
Spartanburg SC
Personally I would say they are not worth it for your mild build. You will not see any HP improvement. If your originals have a ton of miles I would replace them with OEM or Hughes engines (they advertise here) has a good replacement set...just don't believe the EXTRA expense of the H/S rocker would help you. Spend the money on: port / bowl blend work / quality valve job...there you will see improvement
my
Re: Harland-Sharp roller rockers vs. OEM [Re: stryker63] #671580
04/16/10 05:24 PM
04/16/10 05:24 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
You did not mention it or not- The HS rockers come in two ratios (stock 1.6 or 1.7)
I used the 1.7's on my 2000 Durango and it made more power upstairs around 4500+ rpm.
Only other mods was a muffler and bored throttle body.
Re: Harland-Sharp roller rockers vs. OEM [Re: gdonovan] #671581
04/16/10 07:28 PM
04/16/10 07:28 PM
I was looking at using the 1.6 ratio
Re: Harland-Sharp roller rockers vs. OEM [Re: stryker63] #671582
04/16/10 08:06 PM
04/16/10 08:06 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I'd not waste the funds then.
