do mopars just get low oil psi or is it just mine? #671459
04/16/10 01:51 PM
04/16/10 01:51 PM
Clinton Twp. Michigan
coronet1966d Offline OP
the 360 i pulled out would idle at about 12psi hot with 20w50
now my fresh 440 with a high volume pump gets about 8psi hot idle with brad penn 10w30
the engine is all new and assembled by a machine shop, clevite bearings melling high volume pump ect. on cold startup its at about 75psi. then it gradually drops as it warms up. the oil pressure is responsive as it should be to engine RPM. when hot it goes up to 50psi at most
any ideas?
Re: do mopars just get low oil psi or is it just mine? [Re: coronet1966d] #671460
04/16/10 02:04 PM
04/16/10 02:04 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
What oil gauge, what temp and what idle speed?
Re: do mopars just get low oil psi or is it just mine? [Re: coronet1966d] #671461
04/16/10 02:07 PM
04/16/10 02:07 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
My fresh build (small block) had a high volume pump. I seized it with a small piece of trash that got sucked in. I replaced it with a melling standard flow. My gauge still reads 10-15 at idle (900 rpm) and stays at or above 10psi per 1000rpm.
Gotta be loose bearing clearances? I also run the purple 10w30 synthetic.
Re: do mopars just get low oil psi or is it just mine? [Re: radar] #671462
04/16/10 02:17 PM
04/16/10 02:17 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I have nothing that has that low of pressure even with many thousands of miles on them.
Re: do mopars just get low oil psi or is it just mine? [Re: MoparforLife] #671463
04/16/10 02:21 PM
04/16/10 02:21 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My old 318 had 280K and at idle hot had like 10 psi.Ran for 4 years till I sold it and was running good after at least 3 more years that I know of.My 440 hi press hi vol pump has 80 cold and never drops below 65.My kis 62 413 carries 60 cold and minimum 45 hot.Rocky
Chrysler Firepower
Re: do mopars just get low oil psi or is it just mine? [Re: stumpy] #671464
04/16/10 03:32 PM
04/16/10 03:32 PM
its an autometer short sweep electric 0-100psi
temp at idle is about 150 but it gets as high as 180
idle speed is about 1000
Re: do mopars just get low oil psi or is it just mine? [Re: radar] #671465
04/16/10 03:36 PM
04/16/10 03:36 PM
yours sounds exactly like mine. (minus the seized oil pump part) this is a tight fresh engine with no more than 40 miles on it. a machineist did the lower end i assembled the rest
Re: do mopars just get low oil psi or is it just mine? [Re: coronet1966d] #671466
04/16/10 03:40 PM
04/16/10 03:40 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
Corny ... it sound like you have a L O S S E L Y clearanced motor.
Re: do mopars just get low oil psi or is it just mine? [Re: coronet1966d] #671467
04/16/10 04:09 PM
04/16/10 04:09 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
Clearances are probably on the loose side. Also high volume isn't the same as high pressure. I use a high pressure spring in any modified engine. With 20-50 weight oil my cold pressure is 75-80 psi. Hot idle is 40 psi, 30 psi if it's been run hard. Hot pressure at 2000 rpm is 60-65 psi. Pressure is 5 psi lower when using thinner oils. Most stock Mopars run 45-50 psi at 2000 rpm hot and anything from 15-30 psi at hot idle.
Re: do mopars just get low oil psi or is it just mine? [Re: 5spdcuda] #671468
04/16/10 04:17 PM
04/16/10 04:17 PM
Dalton, MA
Slipknot440 Offline
Slipknot440  Offline
Dalton, MA
my hemi idles at 900 rmps and 60psi in park, 15-20 psi in drive on the brake and drives around 50 at 1500-3000 rpms
Re: do mopars just get low oil psi or is it just mine? [Re: Slipknot440] #671469
04/16/10 04:55 PM
04/16/10 04:55 PM
Grand Prairie,Texas
Grand Prairie,Texas
You need to get that engine temp up to a least 190* for the engine to be at it's best.
Re: do mopars just get low oil psi or is it just mine? [Re: coronet1966d] #671470
04/16/10 05:05 PM
04/16/10 05:05 PM
USA
JoesMopar Offline
JoesMopar  Offline
USA
My:
440 in '69 Charger - 70psi @ cold idle, 50psi warm idle and cruising... GTX 20W-50
318 in '89 Diplomat - 55psi @ cold idle, 50psi crusing warmed up, 25 psi warm idle... Napa 10W-30
318 in '68 Satellite - 70psi @ cold idle, 60 psi crusing and warm idle... Napa 10W-30
Re: do mopars just get low oil psi or is it just mine? [Re: coronet1966d] #671471
04/16/10 05:05 PM
04/16/10 05:05 PM
now my fresh 440 with a high volume pump gets about 8psi hot idle with brad penn 10w30.
the oil pressure is responsive as it should be to engine RPM. any ideas?
go w the next thicker grade. Actually if it jumps up immediately when you gun it you are Ok though 8 is getting close to the ragged edge. I'd think loose clearances also, somewhere
Re: do mopars just get low oil psi or is it just mine? [Re: RapidRobert] #671472
04/16/10 05:12 PM
04/16/10 05:12 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I have a 1981 International truck with a 345 ci gas engine in it. When it idles it has 1-2 lbs oil pressure when hot. when you gas it it jumps up. Been that way since I bought the truck 15 years ago. It's a old utility truck with a crane mounted on it. I suspect it idled all day long when it was in service for the utility company. Anyway it won't die, it just keeps on running sometimes for hours at a time for us with the dash gauge showing 0.
Anyway to the OP, That sounds too low for a new engine. I'm thinking some bearings got wiped during start up? Sorry not good.
Might want to cut a oil filter apart to rule out what I'm saying.
Re: do mopars just get low oil psi or is it just mine? [Re: dOoC] #671473
04/16/10 05:42 PM
04/16/10 05:42 PM
S.E. Conn
Hoof Hearted Offline
S.E. Conn
I'm guessing he meant L O O S E L Y
but I agree.
2005 300C Hemi
2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: do mopars just get low oil psi or is it just mine? [Re: 5spdcuda] #671474
04/16/10 05:46 PM
04/16/10 05:46 PM
where can i get a high pressure spring?
Re: do mopars just get low oil psi or is it just mine? [Re: coronet1966d] #671475
04/16/10 05:53 PM
04/16/10 05:53 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
M P has them so any Chrysler dealer or M P dealer such as Mancini, Hensley, Muscle Motors etc. Costs about $5.00.
Re: do mopars just get low oil psi or is it just mine? [Re: 5spdcuda] #671476
04/16/10 05:58 PM
04/16/10 05:58 PM
i guess ill try that before heading over to the machineists house with torches
Re: do mopars just get low oil psi or is it just mine? [Re: Hoof Hearted] #671477
04/16/10 09:03 PM
04/16/10 09:03 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
but I agree.
Oooooops !
...and me thimks your machinist needs to go back to FIRST GRADE !
Re: do mopars just get low oil psi or is it just mine? [Re: dOoC] #671478
04/16/10 09:19 PM
04/16/10 09:19 PM
scratchnfotraction Offline
I beg to differ here
electric guages just show its working some and IMO are not a reliable as a mech guage
I had the same thing till I went back to the mech autometer gauge
i say put a mech on and check it first before working on something thats not broke
my sb 318 holds 25 hot idle in gear at 850rpms 75 at 2500rpms almost 250,000 miles on it
my BB used engine 75,000 miles was low pessure on elect gauge and flickerd the stock oil light in the dash
swaped to the mech gauge
now its up around 70 hot and 30 at hot idle
sender was going bad maybe,it would be at 30lbs on mech gauge and flicking the oil light on the elect gauge compairing the 2 at the same time
cant believe all you have in that 440 and its on the loose side
did you do any oil mods? full groove bearings?
did you get your seal fixed?
how was the lifter bores?? in spec on the bore size?
IMO,I would double check with mech gauge first move to see if the gauge is correct
result will vary by gauge,IMHO
