65 Imperial park sprag adjustment #671317
04/16/10 09:55 AM
04/16/10 09:55 AM
DRAG-ULA Offline OP
DRAG-ULA  Offline OP
A friend of mine just got a 65 Imperial, and when you put it in reverse the park sprag isn't disengaged all the way and it clatters like hell. I've never messed with pushbutton transmissions. Thanks in advance guys.
1970 Imperial, Low & slow daily driver
1973 Chrysler T&C
1948 Dodge B1 pickup - perpetual project
Re: 65 Imperial park sprag adjustment [Re: DRAG-ULA] #671318
04/16/10 10:17 AM
04/16/10 10:17 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
park sprag is activated by the cable in the tail housing. there is a fastener with a nut that holds the cable in place. back off the nut until the cable can move freely in the housing. pull the cable out until the park sprag is fully disengaged and retighten the fastner nut.
Re: 65 Imperial park sprag adjustment [Re: lewtot184] #671319
04/16/10 03:22 PM
04/16/10 03:22 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
NOTE: When performing the above adjustment the shifter must NOT be in Park.
Also, just backing off the nut on the cable lock stud won't usually loosen the cable, you need to tap on the end of the of the stud to loosen it.
