dana 60 carrier differences #671287
04/16/10 06:07 AM
04/16/10 06:07 AM
Ky
jt4406 Offline OP
jt4406  Offline OP
Ky
Putting a 3.54 in the place of a 6.50
Will I need a different carrier? Would it have been possible to run that gear on what was originally a 3.54 carrier if it had a ring gear spacer?
thanks
Jess
Yeah, it's hopped up to over 160...
Re: dana 60 carrier differences [Re: jt4406] #671288
04/16/10 07:51 AM
04/16/10 07:51 AM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
Up to 4:10 on the small carrier. Then you have to add a spacer to go with a larger gear or go with the larger carrier. See if you have the spacer now, if you do just remove it.
Re: dana 60 carrier differences [Re: jt4406] #671289
04/16/10 03:35 PM
04/16/10 03:35 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
4.56 is usually the cutoff for the carrier, that ratio and anything numerically higher have a thinner ring gear and need a carrier for those ratios or a .188" ring gear spacer.
If the carrier you now have mounts the 6.50 ring gear without a spacer you will need a different carrier for the 3.54's.
