Re: Muscle car oil
[Re: fury4speed]
#671207
04/18/10 08:26 AM
04/18/10 08:26 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
I think the Valvoline VR 1 20/50 has or close to the highest Zinc content for off the shelf Oil at your local parts stores , but if you want some Oil with all the good stuff in it use BradPenn Oil , they also make a Break-in Oil. The BradPenn also has more Zinc in it than the Joe Gibbs Oil if I remember right.
http://www.bradpennracing.com/
And here is a Brad Penn analysis I had done over a year ago,only way to be sure.Go compare,most others aren't even close.
Re: Muscle car oil
[Re: 70SWGR]
#671213
04/18/10 02:21 PM
04/18/10 02:21 PM
Posts: 21,831 Kirkland, Washington
Pacnorthcuda
Where do you find the ZDDP additive?Is that the actual name on the label?Is the Comp additive the same thing?
ZDDPlus is available on Ebay. The stuff comes in a 4 oz bottle for about $10. Its something like 57,00PPM of Zincdilithiophosphate (sp?) so if you do the math even 1/2 bottle is enough for an oil change IF you're starting with an oil that contains, say, at least 900PPM to start with. I've heard from several sources that Comp Cams additive is actually a mega-doze of Moly. Which does work for the intended purpose. I use ZDDPlus.
Re: Muscle car oil
[Re: 62maxwgn]
#671216
04/19/10 09:16 AM
04/19/10 09:16 AM
Posts: 1,019 Eau Claire, WI
ResQ911
super gas
super gas
Eau Claire, WI
I would not use anything else............
