Re: 75 amp Alternator
[Re: kieron_kohlmann]
#671173
04/16/10 02:05 AM
04/16/10 02:05 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
so i have a 50 amp alternator and it doesnt have enough juice to keep up. i cant seem to find a 75 amp. alternator that isnt chrome. any one have some ideas?
simply stock lates 70s alts...
PNs Beck/Arnley 186-6002, dual pulley but can be changed...
http://c2c.activant.com/ctoc/index.jsp?ID=gGA1KJhwDA0dBFR0MaSREf2RHG1R.AxgIX3dOTwEEXxkA
available at Clearly Auto on $32.78 plus $15 core
http://www.clearlyauto.com/catalog/1974/...tors-Generators
it is dual field... if you have single field setup, simply ground one of the brushes
it is A LITTLE BIT WIDER than roundbacks and earliers squarebacks due the wider windings at stator, so will fit TIGHT ( rear spacer can be milled down a liitle bit too ). recomended use a little bit longer belt to keep away the back of alt from block.
more reading about same alt installation: http://www.moparmusclemagazine.com/techa...ator/index.html
IMPORTANT... UPGRADE MAIN CHARGE WIRES: http://www.dodgecharger.com/forum/index.php/topic,33574.0.html
more readings about ( including the one above ) here:
http://www.dodgecharger.com/forum/index.php/topic,62772.0.html
#671174
04/16/10 09:41 AM
04/16/10 09:41 AM
Posts: 1,822 Colorado
denfireguy
Colorado
You can also rebuild your own alternator. The only appearance issue is that it will be slightly thicker. http://store.alternatorparts.com/daimlerchrysler.aspx
One caution: Your bulkehead connector is not rated to handle that much current. Use the factory manual to convert to police/taxi wiring for 55Amps and above. It is in the Satellite and Fury wiring diagrams for Plymouth, Coronet, Diplomat diagrams for Dodge. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: BDW]
#671179
04/16/10 08:15 PM
04/16/10 08:15 PM
Posts: 4,481 Mesa, AZ
Pat_Whalen
super gas
super gas
Mesa, AZ
I was looking at RockAuto and they list alternators from 50-100A, give them a look.
To the best of my knowledge, the 100A versions require a completely different mounting scheme.
