Fuel line mushroom flare tool? #671151
04/15/10 10:17 PM
04/15/10 10:17 PM
Indiana
MonGoo$e Offline OP
MonGoo$e  Offline OP
Indiana
Seems I've seen one before but I'm drawing a blank, I know you can do the old Tranny line style flare but I'm curious about the mushroom headed flare the factory used on the rubber hose ends of the steel line. Prefitting subframe connectors I decided it will be best if I route the line on pass side away from the E-brake rod and vent tube, the connector will compress all 3 together and thats a in my book.
thanks
My YouTube Channel, "Hoosier Garage"
https://www.youtube.com/HoosierGarage
Re: Fuel line mushroom flare tool? [Re: MonGoo$e] #671152
04/15/10 10:34 PM
04/15/10 10:34 PM
IN
ahy Offline
ahy  Offline
IN
A basic double flare kit will do it. Extend the tube farther than usuual and use the "button". With the right press, it will make a "bubble" or "mushroom". Practice on scrap tube first!
Re: Fuel line mushroom flare tool? [Re: ahy] #671153
04/15/10 11:07 PM
04/15/10 11:07 PM
Indiana
MonGoo$e Offline OP
MonGoo$e  Offline OP
Indiana
Okay cool, I was under the impression there was a certain flare the factory did that a tool wouldn't duplicate I just dunno which one it was, as long as I can get a nice bubble flare I'll feel good about it. thanks
