Re: Water Restrictor Plates
[Re: RBSat66]
#671094
04/15/10 10:04 PM
04/15/10 10:04 PM
RapidRobert
No restrictor plate. I'd get a stant or milodon 180 stat, check it suspended in a pot of boiling water to see if it opens (occaisionally a new one is stuck)(work it by hand with your thumbs before you suspend it) and that it opens close to it's rated temp and I like to drill a 1/16" hole in the flat so it'll fill up wo an air pocket easier or fill it to just below the stat mounting flat then install the stat/housing
