Water Restrictor Plates #671093
04/15/10 09:48 PM
04/15/10 09:48 PM
Stow,Ohio
RBSat66 Offline OP
RBSat66  Offline OP
Stow,Ohio
I'm thinking about using restrictor plates in my street motor,is this a good idea or should I just install a thermostat? I want the motor to stay around 180 degrees.
Re: Water Restrictor Plates [Re: RBSat66] #671094
04/15/10 10:04 PM
04/15/10 10:04 PM
No restrictor plate. I'd get a stant or milodon 180 stat, check it suspended in a pot of boiling water to see if it opens (occaisionally a new one is stuck)(work it by hand with your thumbs before you suspend it) and that it opens close to it's rated temp and I like to drill a 1/16" hole in the flat so it'll fill up wo an air pocket easier or fill it to just below the stat mounting flat then install the stat/housing
Re: Water Restrictor Plates [Re: RapidRobert] #671095
04/15/10 10:07 PM
04/15/10 10:07 PM
Stow,Ohio
RBSat66 Offline OP
RBSat66  Offline OP
Stow,Ohio
Okay, Thanks for the reply.
Re: Water Restrictor Plates [Re: RBSat66] #671096
04/15/10 10:21 PM
04/15/10 10:21 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
My brother once tried a restrictor disc and the engine never got hot enough.
