what is the correct fan blade for a 64 sport fury???? #671083
04/15/10 09:45 PM
04/15/10 09:45 PM
bigblockSfury Offline OP
What should the stock fan blade for a 64 sport fury look like? Right now it has a 17.5 in. dia. fixed four blade fan. The car will overheat if I let it set long enough at idle. I hope no one tells me what I have is correct. The car was a 383 and someone put a 440 in it. The car does not have a fan shroud.
I really wanted to switch to a clutch fan from a later model to gain back some power however I do not have enough room between the water pump and the radiator. I know there are a lot of opinions on here so if you have a fan you like that would work for my application let me know.
Re: what is the correct fan blade for a 64 sport fury???? [Re: bigblockSfury] #671084
04/15/10 10:52 PM
04/15/10 10:52 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Changing fans won't do any good until you get a shroud on the radiator.
Re: what is the correct fan blade for a 64 sport fury???? [Re: bigblockSfury] #671085
04/15/10 11:30 PM
04/15/10 11:30 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
Sounds like they kept the same small radiator after going to a 440. I would switch to an aluminum rad..
http://motors.shop.ebay.com/__?_from=R40...tor&_sacat=
Re: what is the correct fan blade for a 64 sport fury???? [Re: bigblockSfury] #671086
04/16/10 01:01 AM
04/16/10 01:01 AM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
I have a 4 blade in my 62 dart 500 stroker and a 4-core rad I dont seem to have any problems.
Re: what is the correct fan blade for a 64 sport fury???? [Re: moparsquid] #671087
04/16/10 07:07 AM
04/16/10 07:07 AM
Where did you get your rad?
Thanks for the information guys! I knew a shroud was a good idea; i just dont want to spend a couple hundred dollars to get one. Although it may be cheaper than a new rad depending on what kind I pick.
Re: what is the correct fan blade for a 64 sport fury???? [Re: bigblockSfury] #671088
04/16/10 08:08 AM
04/16/10 08:08 AM
Madison, Wisconsin
chrisnben Offline
chrisnben  Offline
Madison, Wisconsin
hey Fury, I have a 7-blade 18" fan I am not using. Pick up a shroud for $100- maybe less and this combo will work great. PM if you want it.
'70 Cuda "Badfish 2"- in the works
Home of MoPar University- We school 'em one at a time!!
Re: what is the correct fan blade for a 64 sport fury???? [Re: bigblockSfury] #671089
04/16/10 08:58 PM
04/16/10 08:58 PM
templeton,ma
coro500net Offline
coro500net  Offline
templeton,ma
The 4 blade should be correct,my 65 coronet with a 361 had that fan,and yes it did run hot.
Re: what is the correct fan blade for a 64 sport fury???? [Re: coro500net] #671090
04/17/10 03:14 PM
04/17/10 03:14 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
There is a repop metal shroud available for the 64 fury....Mancini carries one but I'm not sure on the real source...An original 64 Max Wedge car had a clutch fan but it was shorter than anything available over the counter now...There was also a 65 clutch fan available that was very short but I can't remember the application...The parts store jaguar fan clutch that everyone is using {for tight clearance} might fit in there depending on how much room you actually have between there... I have an old style 7 blade fixed I use occasionally for parade duty but it sounds like an airplane prop when you wind up the engine...
Re: what is the correct fan blade for a 64 sport fury???? [Re: screamindriver] #671091
04/19/10 12:53 PM
04/19/10 12:53 PM
I have been trying to convince myself to buy mancini's re pop shroud. They are proud of it$$$$
I will check into the jaguar fan clutch. Thanks for all of the information everyone.
Re: what is the correct fan blade for a 64 sport fury???? [Re: bigblockSfury] #671092
04/19/10 01:04 PM
04/19/10 01:04 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
My bud's 64 has no fan shroud and has a hard time getting up to 180. He does have a clutch fan.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
