Re: Turn Signal Switches why they go bad?
[Re: 52savoy]
#670915
04/15/10 11:38 PM
04/15/10 11:38 PM
fury4speed
I'll try this again.. the brake light power is routed through the column. Look for a broken wire there.
Will do , thanks again for all your replies.
[Re: fury4speed]
#670916
04/15/10 11:43 PM
04/15/10 11:43 PM
Posts: 4,231 State of retirement
52savoy
State of retirement
Do you have an ohm/volt meter? If you do, disconnect the battery and check continuity(ohms) on both ends of the column harness. One wire at a time..red to red, yellow to yellow and so on. The needle on the meter should peg out unless there is a break. good luck.
[Re: fury4speed]
#670918
04/15/10 11:52 PM
04/15/10 11:52 PM
52savoy
State of retirement
Set the meter to ohms and turn it on. Touch the leads together and turn the meter dial until until the hand pegs out..unless it's digital but it works on the same principal. Check your wires then and with a good connection it should "peg out"
[Re: fury4speed]
#670920
04/16/10 12:14 AM
04/16/10 12:14 AM
Posts: 9,312 SoCal
68HemiB
SoCal
It could be a broken wire, it could be bad contacts. The net result is the same - the circuit is open, and not passing electricity.
At the risk of restating what has been said previously, the design is NECESSARY when the bigger/brighter filament in the bulbs at the rear of the car perform TWO functions - turn signal and brake. Imagine following behind yourself as you slow for a right turn: You apply the brakes at the same time that you are signaling for the turn. The left side brake light stays on solid, and the right side BLINKS. This is accomplished by routing the brake light circuit through the turn signal switch. Every time you signal one way or the other, the brake light circuit on that side OPENS (regardless if you are stepping on the brakes or not), and power from the flasher is applied instead. The signaling that happens day after day, year after year wears the contacts out so that they no longer make a circuit even when you are not signaling. It's just a fact of life of this particular design.
You can avoid it by never signaling again, or driving a car with separate [amber] turn signals at the rear.
Down to just a blue car now.
[Re: fury4speed]
#670922
04/16/10 01:02 AM
04/16/10 01:02 AM
Posts: 357 Lake Elmo, MN
Evil Monkey
Lake Elmo, MN
Quote: Every light works except the Brake Lights , I have that problem on another discussion , just seems if the turn signals work and the brake lights do not what's up?
The first thing I would look at if the turn signals work and the brake lights do not is the brake light switch on the pedal assembly. If that's stuck or broken, when you depress the brake pedal, the switch won't activate and the brake lights won't come on, but the turn signals will still work fine.
1974 'Cuda 360/TKO
1990 Ram Van
1998 Neon
