where to buy yellow headlight for quad headlights #670838
04/15/10 06:54 PM
04/15/10 06:54 PM
Tampa FL
hemibeep Offline OP
hemibeep  Offline OP
Tampa FL
Does anyone have a source for yellow headlights for high beam location on quad setup.? 5.75"
thanks
Re: where to buy yellow headlight for quad headlights [Re: hemibeep] #670839
04/15/10 07:25 PM
04/15/10 07:25 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
You could buy the NAPA tractor lights, but you'll need to change the terminal end that plugs into the bulb,...or you could use the Dupli-Color "gold anodize" spray paint, very translucent, you can spray as many coats as you wish to obtain the desired tint,...although it listed as gold, it's actually yellow, has a nice "candy" look to it, you'd be had pressed to tell the difference between it and "real" tinted yellow light bulbs,....it's also avaliable in blue, green, red
Mike
Re: where to buy yellow headlight for quad headlights [Re: DAYCLONA] #670840
04/15/10 09:26 PM
04/15/10 09:26 PM
Tampa FL
hemibeep Offline OP
hemibeep  Offline OP
Tampa FL
wow,, thanks for the tip.
