1989 360 high stall torque converter #670827
04/15/10 06:37 PM
04/15/10 06:37 PM
arizona
fmcgraugh2 Offline OP
arizona
Here's my set up 1985 ramcharger with a '89 360 LA motor running a voodoo 60711 cam 727 trans with an 8.25 ring gear and 294 ration, summit headers - wanna use a high stall stock torque converter but I done know what vehicles came with a stock high stall Torque converter. Any suggestions or help period would be greatly appreciated.
Re: 1989 360 high stall torque converter [Re: fmcgraugh2] #670828
04/15/10 06:58 PM
04/15/10 06:58 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I will not try to preach, but with such a freeway oriented gear ratio, do you really want a high stall converter? If so... Truck 318 engines may have a higher stall than the 360...The smaller engine needs to spin a little more since it has less torque. The factory 383 HP and 340 engines had the highest stall speeds, but they are getting scarce. A new one may be the easiest route to take. A good trans or converter shop will be able to weld the required balance weight on the converter. Otherwise, you could use the B&M flexplate for a 360.
Re: 1989 360 high stall torque converter [Re: Kern Dog] #670829
04/15/10 07:13 PM
04/15/10 07:13 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
The thing being is that the unit in question will very likely have a lock up and the converter s mentioned will most likely be non lockup.
Also stall speeds vary with a converter. One that will stall at 1500 behind a 318 may well stall at 2000 behind a 383 01700 behind a torky 360.
Re: 1989 360 high stall torque converter [Re: MoparforLife] #670830
04/15/10 08:49 PM
04/15/10 08:49 PM
Az
Crizila Offline
Crizila  Offline
Az
For sure the 79 300's and Magnums came with "Hi Stall" convertors. They were rated by Chrysler @ 2200 to 2400 rpm behind the E58 360 motor.
Fastest 300
Re: 1989 360 high stall torque converter [Re: Crizila] #670831
04/16/10 01:48 AM
04/16/10 01:48 AM
arizona
arizona
To be perfectaly honest I dont know anything bout torque converters i was told by another moparts member that a high stall converter would be best as im building this set up for a daily driver BUT I want some torque and power also in the future im looking to goto 3.55 gears.
Re: 1989 360 high stall torque converter [Re: fmcgraugh2] #670832
04/16/10 01:57 AM
04/16/10 01:57 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
I get you. The 2.94 gears with a standard 31 inch truck tire will make the truck a little lazy off the line. The less torque the engine has, the more stall it needs. A slant six will need more stall speed in a truck than a 440. Another guideline: Lower gears( 3,91, 4.10 ) can get by with higher stall since they get the engine up to speed quicker. A tall tire, tall gears and high stall speed will create much more heat in the transmission and make your truck a real slug out of the hole.
Re: 1989 360 high stall torque converter [Re: Kern Dog] #670833
04/16/10 09:25 AM
04/16/10 09:25 AM
scratchnfotraction Offline
local tranz shop
ask for a stock high stall TC (loc up or non lock depending on your tranz)
want it balanced for a 360
around 120$ at my tranz shop
gear swap is in the future IIRC
E58 cop engine for specs if they ask
Re: 1989 360 high stall torque converter [Re: scratchnfotraction] #670834
04/16/10 04:11 PM
04/16/10 04:11 PM
arizona
arizona
Here's a couple of pics of my trans
Re: 1989 360 high stall torque converter [Re: fmcgraugh2] #670835
04/16/10 04:31 PM
04/16/10 04:31 PM
arizona
arizona
I
Re: 1989 360 high stall torque converter [Re: fmcgraugh2] #670836
04/16/10 09:27 PM
04/16/10 09:27 PM
looking at the input shaft its a non lock up tranz
Re: 1989 360 high stall torque converter [Re: fmcgraugh2] #670837
04/16/10 09:35 PM
04/16/10 09:35 PM
and it has the newer lever on the throttle pressure valve..ball stud linkage connection
I vote stock high stall 360 TC with 3.55 gear 11.00x15 tire 26.5' tall
750cfm 4-v carb
LD340 intake
headers and 2.5 duels
your cam pic lunati 60711 voodoo roller cam
will make a very nice street RC for daily driving
the stock HS TC is gonna help ge that heavy RC rolling with the torque of the 360
hey..thats just my
