SB DRY SUMP SYSTEMS??????????? #670741
04/15/10 04:21 PM
04/15/10 04:21 PM
united kingdom
blown360 Offline OP
blown360  Offline OP
united kingdom
Im contemplating running a dry sump system on my smallblock R3/W9 build but really know nothing about it! My blocks a wet sump 9.2 deck R3 is this easily converted to run dry sump? What parts do I need to convert to dry sump and how do i do it? Can I use any make of pump or do I need mopar specific parts? How do I mount the pump and what type of pump do I need? What size tank etc etc...?Who even sells the stuff I need? Really guys any info would be great because im really stuck here!
Re: SB DRY SUMP SYSTEMS??????????? [Re: blown360] #670742
04/15/10 05:15 PM
04/15/10 05:15 PM
AndyF Offline
AndyF  Offline
Here is a 340 W2 dry sump mockup that I was working with the other day.
Re: SB DRY SUMP SYSTEMS??????????? [Re: blown360] #670743
04/15/10 05:17 PM
04/15/10 05:17 PM
AndyF Offline
AndyF  Offline
Here is a thread of mine in the archives. If you use the search function you'll find even more information.
https://board.moparts.org/ubbthreads/show...e=0#Post4819530
Re: SB DRY SUMP SYSTEMS??????????? [Re: AndyF] #670744
04/15/10 05:27 PM
04/15/10 05:27 PM
united kingdom
blown360 Offline OP
blown360  Offline OP
united kingdom
So am I right in saying I can adapt any pump to suit my engine? Ive seen loads for sale but not sure what to go for or how it would mount?
Re: SB DRY SUMP SYSTEMS??????????? [Re: blown360] #670745
04/15/10 05:37 PM
04/15/10 05:37 PM
St.Louis, Mo.
mokid Offline
mokid  Offline
St.Louis, Mo.
I have dry sump on my R3 W8 motor and all I can say is if your motor has wet sump now keep it, It more hassel then its worth. with all the lines, remote filter, oil canaster, pump, new belt drive, In short don't do it.
Re: SB DRY SUMP SYSTEMS??????????? [Re: mokid] #670746
04/15/10 05:53 PM
04/15/10 05:53 PM
united kingdom
blown360 Offline OP
blown360  Offline OP
united kingdom
Im just about to start hyaving the motor built and I figured it would be much safer to run it at high rpm with a dry sump system. Only thing is I know nothing about it!
Re: SB DRY SUMP SYSTEMS??????????? [Re: blown360] #670747
04/15/10 05:56 PM
04/15/10 05:56 PM
AndyF Offline
AndyF  Offline
Well like most things, it is quite simple once you understand it. Read the thread that I linked to and then do a search for other dry sump threads on here. Lots of parts are available for the SB. I had to build some parts for my BB but the SB motor is used heavily by circle track racers and most of them run dry sumps. So there are lots of dry sump parts available for SB engines. You just need spend some time looking.
Re: SB DRY SUMP SYSTEMS??????????? [Re: AndyF] #670748
04/15/10 06:18 PM
04/15/10 06:18 PM
Mcallen, TX
SB449VALIANT Offline
Mcallen, TX
Re: SB DRY SUMP SYSTEMS??????????? [Re: blown360] #670749
04/15/10 06:23 PM
04/15/10 06:23 PM
AndyF Offline
AndyF  Offline
You'll want to get the block machined so you can run oil lines into the block. This is a wet sump block, on a dry sump block you won't have the lower line. The factory block has a 3/8 NPT fitting there which might be large enough or you might want to open it up. If you're going to scavange from the valley you'll need a fitting up there also.
Re: SB DRY SUMP SYSTEMS??????????? [Re: blown360] #670750
04/15/10 08:05 PM
04/15/10 08:05 PM
StewartP Offline
Mopar Vintage Picture Guy
StewartP  Offline
Re: SB DRY SUMP SYSTEMS??????????? [Re: StewartP] #670751
04/15/10 08:05 PM
04/15/10 08:05 PM
StewartP Offline
StewartP  Offline
Re: SB DRY SUMP SYSTEMS??????????? [Re: blown360] #670752
04/15/10 09:14 PM
04/15/10 09:14 PM
AndyF Offline
AndyF  Offline
Here is a drive plate that I make for Mopar engines. I designed it for big blocks but it should fit a SB because the bolt pattern is the same. You might find similiar products from Moroso or CV Products.
Re: SB DRY SUMP SYSTEMS??????????? [Re: StewartP] #670753
04/15/10 09:16 PM
04/15/10 09:16 PM
St.Louis, Mo.
mokid Offline
mokid  Offline
St.Louis, Mo.
Don't Do It.
Re: SB DRY SUMP SYSTEMS??????????? [Re: AndyF] #670754
04/15/10 09:28 PM
04/15/10 09:28 PM
south central pa
bdaz smblk Offline
bdaz smblk  Offline
south central pa
If you don't mind me asking how much do you get for one.Thats a really nice piece.Thanks Kenny
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
Re: SB DRY SUMP SYSTEMS??????????? [Re: bdaz smblk] #670755
04/16/10 01:32 AM
04/16/10 01:32 AM
AndyF Offline
AndyF  Offline
The six bolt Mopar pattern drive plate is part number AR236. You can get them from Mancini Racing for $145. I don't know anyone else who makes a spline drive setup for Mopar engines but maybe there is someone out there.
Re: SB DRY SUMP SYSTEMS??????????? [Re: AndyF] #670756
04/16/10 01:34 AM
04/16/10 01:34 AM
AndyF Offline
AndyF  Offline
I also make them in the Chevy bolt pattern. Lots of guys run a Mopar damper with the Chevy front bolt pattern because then it is easier to buy drives and pullies.
Re: SB DRY SUMP SYSTEMS??????????? [Re: AndyF] #670757
04/16/10 01:35 AM
04/16/10 01:35 AM
AndyF Offline
AndyF  Offline
I make several different block plates for big block and Hemi motors but of course, small blocks don't need these.
Re: SB DRY SUMP SYSTEMS??????????? [Re: AndyF] #670758
04/16/10 01:38 AM
04/16/10 01:38 AM
AndyF Offline
AndyF  Offline
Here is a shot of that 340 W2 dry sump motor being dropped into an early B body car. It all fit just fine. The dry sump pan cleared the steering linkage okay and the Doug Nash five speed lined up just fine with everything once all the mods were complete to the sheet metal.
Re: SB DRY SUMP SYSTEMS??????????? [Re: AndyF] #670759
04/16/10 10:19 AM
04/16/10 10:19 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Here's a pic of my setup...
Here's a pic in the car with the sheetmetal off...
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
