New to manual brakes, is this normal? #670720
04/15/10 04:04 PM
04/15/10 04:04 PM
Townsville
3
3_wheelie Offline OP
Townsville
Ive recently buttoned up the brake system on my 67 dart after doing the front disc swap, and the brakes just dont feel right. There doesnt seem to be any resistance at all compared to what im used to expecting from brakes, and the pedal goes all the way to the floor before the car will even slow down. Im 100% sure on all the brake components and thier is no air in the lines as ive gone through all that stuff many times over. Is thier something i could be missing or is this just how manual brakes are? And yes i did install the prop valve.Thanks in advance!
YutKillYut Grozny lives!
Re: New to manual brakes, is this normal? [Re: 3_wheelie] #670721
04/15/10 04:18 PM
04/15/10 04:18 PM
Las Vegas
JeffC Offline
JeffC  Offline
Las Vegas
No, something is not right.
Re: New to manual brakes, is this normal? [Re: JeffC] #670722
04/15/10 05:08 PM
04/15/10 05:08 PM
scratchnfotraction Offline
bench bleed the MC and then start at the pass side rear tire working to the closest tire to MC last
you have air in there for sure I would think
are the bleeder up top on the calpers when mounted on the rotor???
did you have all the lines open while working on it
still have the CI 4 bolt MC on it?
Re: New to manual brakes, is this normal? [Re: scratchnfotraction] #670723
04/15/10 05:47 PM
04/15/10 05:47 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Bleed the master by having someone apply light pressure to the pedal, then crack the lines open at the master, then close them, then release the brake pedal. make sure you put a rag under the lines when you crack them open so the drips don't land on paint.
I know that it would seem like the master SHOULD bleed itself as you pump it and push fluid out the lines to the wheels, but it doesnt!
**Photobucket sucks**
Re: New to manual brakes, is this normal? [Re: 3_wheelie] #670724
04/15/10 06:36 PM
04/15/10 06:36 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
If you pump the pedal a few times will the pedal come up and be more firm?
Re: New to manual brakes, is this normal? [Re: 70Cuda383] #670725
04/15/10 08:37 PM
04/15/10 08:37 PM
Townsville
3
Townsville
Every time i bled it i always used the "start at the wheel furthest from the MC" technique, never had more than one bleeder cracked at a time, and yes the bleeders are facing up and at the rear of the spindle. Its actually a 2 bolt MC (I6 car originally, dunno if that makes a diff in MC's tho)
And no amount of pumping makes the pedal seem firmer, always nice and mushy.
Tomm ill try bleeding the MC one more time I guess.
It sucks ive spent my entire boot leave on this thing and its still not right! So dayim frustrating
Re: New to manual brakes, is this normal? [Re: 3_wheelie] #670726
04/15/10 08:44 PM
04/15/10 08:44 PM
Az
Crizila Offline
Crizila  Offline
Az
Manually adjust the rear shoes up tight to the drums and see if the pedal gets better.
Fastest 300
Re: New to manual brakes, is this normal? [Re: 3_wheelie] #670727
04/15/10 09:38 PM
04/15/10 09:38 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Leave huh? where you stationed? yes, this stuff can get frustrating. when I bought my car, I had 3 weeks of summer break at the Academy to get it in road worthy condition and drive it from Ohio back to Colorado. I rebuilt the entire brake system, tore apart the dash and un-did a rats nest of 30 years worth of crappy wire jobs, got all the gauges working properly, re-wired the front lights, tail lights, engine bay, put new bearings in the axle, replaced the ignition system, and had a new exhaust put on it. I even had the seats recovered.
I missed being able to drive it back to Colorado by about 3 days, and had to fly back, then let my dad finish it and drive it out for me on the next long weekend.
Re: New to manual brakes, is this normal? [Re: 3_wheelie] #670728
04/15/10 10:13 PM
04/15/10 10:13 PM
pull the ebrake up tight to see if it's an adjustment prob but from the descrip it sure sounds like air if I'm interpreting the reading right that it is going to the floor. As said bleed the M/C 1st
Re: New to manual brakes, is this normal? [Re: 70Cuda383] #670729
04/15/10 10:26 PM
04/15/10 10:26 PM
Townsville
3
Townsville
Havent even been stationed yet. Graduated recruit training from Parris Island last week, still got months of schooling to go. To top it all off now, i got pulled over today while driving it for the first time for no plates, its 100% my fault obviously, but still makin my day worse...
Re: New to manual brakes, is this normal? [Re: Crizila] #670730
04/15/10 10:57 PM
04/15/10 10:57 PM
MNobody Offline
MNobody  Offline
Re: New to manual brakes, is this normal? [Re: 3_wheelie] #670731
04/16/10 10:54 AM
04/16/10 10:54 AM
Santa Cruz, California
Lefty Offline
Lefty  Offline
What size piston in the manual master cylinder? Did you bottom the piston when bleeding the MC?
Re: New to manual brakes, is this normal? [Re: 3_wheelie] #670732
04/16/10 02:26 PM
04/16/10 02:26 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Is the push rod correct?Most time if no air and Rears adjusted its the Rod.Rocky
Chrysler Firepower
Re: New to manual brakes, is this normal? [Re: 3_wheelie] #670733
04/16/10 03:25 PM
04/16/10 03:25 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Nice. tough luck on the plates, but...you knew what you were doing when you did it!
if you get over to Afghanistan by the end of the year, look me up. but it sounds like you're a ways from going anywhere yet.
Re: New to manual brakes, is this normal? [Re: 70Cuda383] #670734
04/16/10 05:12 PM
04/16/10 05:12 PM
Townsville
3
Townsville
Been busy all day today so no time to screw with the Dart yet, post updates tomorrow. As far as the ticket, case got dismissed and im feelin on top of the world. The way we were told most junior Marines will prolly see Iraq or Afganystan before the years end, so we shall see. You deployed now or building up to it?
