How loud is your valvetrain? #670648
04/15/10 03:21 PM
04/15/10 03:21 PM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
My valve train seems fairly loud compared to my old engine, but I am not sure if it is the result of using the agressive roller cam, the T&D rockers, or the steel valley tray for the Victor heads?
I lashed the valves at 0.015"/0.017" cold, but it is still fairly loud.
Re: How loud is your valvetrain? [Re: 451Mopar] #670649
04/15/10 03:43 PM
04/15/10 03:43 PM
Orlando Florida
blown572dart Offline
Orlando Florida
Don't really know can't hear anything over the exahust.
Re: How loud is your valvetrain? [Re: blown572dart] #670650
04/15/10 03:49 PM
04/15/10 03:49 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Exhaust is way too loud
Re: How loud is your valvetrain? [Re: emarine01] #670651
04/15/10 05:29 PM
04/15/10 05:29 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I'd say mine is loud. and it's a hydraulic flat tappet...being the first engine I've built, I thought something was wrong, I expected the hydraulic to be quiet, but it sounds like a sewing maching running at full tilt under the hood.
someone said that it was normal and sounded fine. 4,000 miles later, they seem to have been correct!
**Photobucket sucks**
Re: How loud is your valvetrain? [Re: 70Cuda383] #670652
04/15/10 07:24 PM
04/15/10 07:24 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Sorry guys but hydralic cams should be quiet. If your valve train is noisey then I bet there's too much lash and it won't last long like that. There's should be zero valve lash when the motor is running and there is oil pressure when properly adjusted. That excludes Roades lifters or the rapid bleed down lifters.
Just saying...
Re: How loud is your valvetrain? [Re: Challenger 1] #670653
04/15/10 07:27 PM
04/15/10 07:27 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
See if you can hear my RBRE / T&D units .......
http://www.youtube.com/watch?v=Ur1y3A23gAg
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: How loud is your valvetrain? [Re: chryco] #670654
04/15/10 07:45 PM
04/15/10 07:45 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Only cars I own with hydraulic rollers are OEM stuff, no noise. My solid-roller car's a bit noisy, maybe almost as much as (dating myself) a solid-lifter 30/30 Duntov-cam SBC. The Street Hemi solid-flat-tappet is clearly audible, maybe a bit more than the 30/30 yardstick. My hydraulic-flat-tappet cars are pretty quiet, even with the lifter preload set at the minimum, unless they've been sitting a long time; in that case any noise isn't much and goes away quickly.
Re: How loud is your valvetrain? [Re: 451Mopar] #670655
04/15/10 07:57 PM
04/15/10 07:57 PM
Dandridge TN
Dabee Online content
Dabee  Online Content
Dandridge TN
My flat tappet hydraulic cam is loud on my BMRE built 512. I had Chuck and Pete listen to it last fall and they said it was normal. Chuck said the aggressive ramps on the new hydraulic cam profiles make them loud. I have between one and one and a half turns of preload on it and it is still loud. I think the fabricated aluminum valve covers also amplify the noise. I have a little over 1000 miles on the engine. I have checked the preload several times and nothing is loose. The car runs great, so I’m not too concerned about it. But yes the tapping is annoying.
Re: How loud is your valvetrain? [Re: Dabee] #670656
04/15/10 08:35 PM
04/15/10 08:35 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Trying to find power in my NA engine I ran some Royal Purple oil that was extremely light. The valvetrain was scary noisy. The car didn't run any faster either. I switched back to Valvoline 10-30 NFS racing oil and ran just as fast and a lot less noise.
Re: How loud is your valvetrain? [Re: 451Mopar] #670657
04/15/10 10:55 PM
04/15/10 10:55 PM
I'm assuming that this motor has a set of eddy RPM heads, if so you shouldset the cold lash at least .006 tighter than what the cam card calls for hot, IE if the card calls for .016 hot on the intake and .018 hot on the EX set the intake at .010 cold and the EX. at .012 cold. Best bet is to set them, warm the motor up to at leeast 180 F long enough to get the oil hot and then check a couple of the settings when hot, if there tight relash all of them up, if there loose check and reset as neccessary My street motor with a Comp Cams solid roller set at .024 hot is noticanbly quiet, many people ask if it has a hydraullic cam and lifters in it, of course it does
Re: How loud is your valvetrain? [Re: Challenger 1] #670658
04/15/10 11:49 PM
04/15/10 11:49 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Just saying...
That's what I thought too, but I had a few folks with more experience than me, tell me that it sounded fine, and normal, that the higher lift and performance oriented cams would make more noise than stock cams, even if they are hydraulic cams. even the guys at the machine shop said it sounded fine, and we checked the "lash" on the lifters SEVERAL times after a bunch of runs to make sure they were staying put.
like I said, 4,000 miles later and no problems yet!
Re: How loud is your valvetrain? [Re: 451Mopar] #670659
04/16/10 09:31 AM
04/16/10 09:31 AM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
When I get back in town, I will have to get my wifes digital camera and do a quick video with sound to post. Monday, I did a video on my cell phone, but the sound quality is really bad, and when I tried to copy the file to my computer all i got was video, no audio?
The cam is a custom comp HXL 264/264 @ 0.050", (187@0.200"), 0.714"/0.714" lift, 112 LSA, 108 cl solid roller cam. Here is comps description of the lobe profiles:
"HXL SERIES ROLLERS
The HXL Series rollers are intended for high lift applications that require maximum torque and extended rpm. These
fall somewhere in between the RX and TK Series in terms of aggressiveness but provide more lobe lift. They are
closest to the High Torque .440" lobes but have incorporated our latest profile advancements that should allow
higher engine speeds and improved dynamics."
The heads are Max wedge port Edelbrock Victors.
Re: How loud is your valvetrain? [Re: 451Mopar] #670660
04/16/10 10:28 AM
04/16/10 10:28 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
I have .016 cold lash, and I couldn't hear it with open headers. I put full exhaust on the duster now and it kinda sounds like an old sewing machine is the best description I can come up with if that makes any sense... SO I would guess it's not as loud as some of the other guys...
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: How loud is your valvetrain? [Re: DemonDust] #670661
04/16/10 02:27 PM
04/16/10 02:27 PM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
I just reset my lash per the old Mopar cam card, set at .023/.027 to allow for the aluminum heads and iron block. filled it with Valvoline VR1 20w50. I was very surpirised how quiet it was. Im not sure if my camera would be able to record well enough for everybody to hear it.
Re: How loud is your valvetrain? [Re: 451Mopar] #670662
04/16/10 03:03 PM
04/16/10 03:03 PM
Canada
RobR Offline
RobR  Offline
Canada
"HXL SERIES ROLLERS
187@200 shouldn't be closing the valve hard enough for you to hear it.
Re: How loud is your valvetrain? [Re: RobR] #670663
04/16/10 03:27 PM
04/16/10 03:27 PM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
Oops, should have said 187 duration at 0.200".
This is just for comparison, the standard Comp solid roller cam with about 187 duration @ 0.200" usually has a 0.050" duration of about 270.
My closed spring pressure is 275#@1.950", and open is around 700+ #.
Re: How loud is your valvetrain? [Re: Dabee] #670664
04/16/10 04:16 PM
04/16/10 04:16 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Rubbing 2 pieces of steel together in an oil bath does not make any noise you could hear in a running engine.
Cyclical noise (ticking, knocking) comes, entirely, from one thing striking another.
It could be rockers taking up end-play on the shaft and reversing, pushrod body smacking the head or block relief hole as it bends, hydraulic lifter compressing (and allowing slack above it) due to the speed and spring load too high for the oil pressure, there are probably others.
Boffin Emeritus
Re: How loud is your valvetrain? [Re: polyspheric] #670665
04/16/10 05:34 PM
04/16/10 05:34 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I agree with Poly that a hydraulic shouldn,t make noise. With that being said I've seen 3 440 street builds in the last year that were noisy. Two had Comp cams one had a generic rebiuld. One motor had the stock rockers,shafts, and lifters replaced with no improvement. All three motors are still currently running with no ill effects. None of these engine were very radical. I never located the source.
Doug
Re: How loud is your valvetrain? [Re: dvw] #670666
04/16/10 05:53 PM
04/16/10 05:53 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
1.6 T&Ds, solid roller
@ 1:09
http://www.youtube.com/watch?v=kcagmy_UnlM
Re: How loud is your valvetrain? [Re: jughed] #670667
04/16/10 07:00 PM
04/16/10 07:00 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
All aluminum top end here with a new lunati Hyd. cam and its fairly noisy in a 11:1 440. I started at 3/4 turn and now up to 1 1/2 turns on the crane golds and its a little quieter and runs perfect.
Most say its the combo of aluminum parts and aggressive cam....not worried about it.
