65 Belvedere 318poly-440 swap questions #67039
06/03/08 09:11 PM
06/03/08 09:11 PM
Houston,Tx.
Lee446 Offline OP
Lee446  Offline OP
Houston,Tx.
I have looked at a couple of Belvedere/Sat 65's lately, and they have both had 318 poly engines. I see that Schumacher has swap mounts to put a 440 in on the stock k-member. The stock k-member brackets look taller on the poly and it got me to thinking about headers for this combo. What all is involved with the swap and who makes headers to fit, and are there any other pitfalls to doing this swap? Thanks, Lee.
Re: 65 Belvedere 318poly-440 swap questions [Re: Lee446] #67040
06/03/08 09:15 PM
06/03/08 09:15 PM
Andrewh Online content
Andrewh  Online Content
there are only a couple of headers that fit. TTI is one and can't remember the other.
Some people swap out to a 66 and up kframe so they can use any headers, but that causes its own problems.
Re: 65 Belvedere 318poly-440 swap questions [Re: Andrewh] #67041
06/03/08 09:23 PM
06/03/08 09:23 PM
MD
Kevins493 Offline
Kevins493  Offline
MD
This may help. We covered it here: 64 - 440 Swap
Re: 65 Belvedere 318poly-440 swap questions [Re: Kevins493] #67042
06/03/08 10:18 PM
06/03/08 10:18 PM
Houston,Tx.
Lee446 Offline OP
Lee446  Offline OP
Houston,Tx.
Thanks!
Re: 65 Belvedere 318poly-440 swap questions [Re: Lee446] #67043
06/03/08 11:42 PM
06/03/08 11:42 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Schumacher's conversion mounts work fine. I run a Max Wedge exhaust system on my car, so I don't know about headers, but a lot of guys run headers, so something must work.
The other issues could be: auto trans shifter, trans mount & crossmember modification, driveshaft & ft yoke, depending on the rest of your swap. I used a '69 RR 4-speed & rearend, stock trans mount, modified the trans crossmember, and had a driveshaft made when I did my '63 (poly stick car).
Re: 65 Belvedere 318poly-440 swap questions [Re: Kevins493] #67044
06/04/08 12:29 AM
06/04/08 12:29 AM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
I thought that was my engine for a second....
Here's mine though
Back to the topic, I did the "new"(66 up) k member swap.
Found it was cheaper than going with schumaker stuff.(75 bucks for a k member) The only real issue was doing some cut up work to the trans crossmember, and cutting the driveshaft to length.
I didn't have a driveshaft for the car either way, so the donar C body shaft had to be shortened anyway, so I didn't figure that was an added expense.
