Re: most inexpensive 383 stroker kit availiable??
[Re: tboomer]
#670296
04/16/10 08:34 AM
04/16/10 08:34 AM
Posts: 86 Pa.
crazytrain
Pa.
[Re: ph23vo]
#670298
04/16/10 06:58 PM
04/16/10 06:58 PM
Posts: 2,588 missouri, USA
moparmojo
missouri, USA
440SOURCE is pretty easy on the pocket book, as far as stroker motor kits go. They have a couple different 383 kits available as well as other parts like heads, gasket sets, water pumps, valve covers, pulleys, etc etc etc. They are prety easy to deal with as well. Check out their website. They are also a site sponsor I believe. There is a couple machine shops also doing stroker motor kits as well that arent too bad on the wallet. Far cry from just a couple years ago when it was hard to get performance parts for our stuff.
[Re: ph23vo]
#670300
04/27/10 04:01 PM
04/27/10 04:01 PM
Posts: 9,336 South-Central (Sebring), FL
Commando1
...who has the best parts for the lowest $$$ thanks dan
Dan, you give me the shudders when you say stuff like that. C-body guys, of all people, know that there's no such thing as best and cheap. I can now give up all hope that I'll ever see a 100 pt. #1 Fury 6-pak...
[Re: ph23vo]
#670301
04/27/10 04:19 PM
04/27/10 04:19 PM
Posts: 5,492 So Cal
Sinitro
So Cal
Why not put a 440 crank in it.. Takes some machining for the block/crank clearance Keeps the outside block looking stock.. Put in the rite cam, heads, intake/carb and exhaust and will easily put out 500HP.. Just my $0.01..
[Re: ph23vo]
#670302
04/28/10 03:19 PM
04/28/10 03:19 PM
Posts: 75,418 A gulag near you.
JohnRR
A gulag near you.
anybody else? know anyone with pieces laying around? dan
Dan I have a set of almost new Diamond flat tops , 1.320 CH , 4.280 bore , .990 pin .
[Re: JohnRR]
#670304
04/28/10 08:05 PM
04/28/10 08:05 PM
Posts: 337 the netherlands
383duster
super street
super street
the netherlands
Hey John, did you get another set and also not using them? 6 years ago I bought a set from you, they are still working perfectly in my 383 upgraded to 449
You won't regret stroking your 383, I did it and with using a 3.91 stroke crank i made it a 449, runs perfect with a Comp XE284 and made 550hp on the dyno last year
[Re: ph23vo]
#670305
04/28/10 08:09 PM
04/28/10 08:09 PM
383duster
super street
super street
the netherlands
john what are they combo,d with crank wise? [stroke] also know anyone with anything used laying around rods and crank wise? thnaks dan
I have the same pistons as John posts and used a 440 crank that is offset grinded to 3.91 stroke and B-block mains, and used chevy BB Scat rods, i run this combo 5 years (about 15.000 miles) now and no problems
[Re: ph23vo]
#670307
04/28/10 08:17 PM
04/28/10 08:17 PM
383duster
super street
super street
the netherlands
thats what i was hoping for i want to run stealth heads will the comp be ok with them? want it to look stock or maybe thats why john isnt using them because of e head chamber dan
I have Edelbrock 84cc heads and my calculated CR is 10.5 , cranking compression is around 180PSI with the XE284 cam, the stealth heads are basicly the same so that won't be a problem
