71 up B body rear sway bar ? #670276
04/15/10 10:11 AM
04/15/10 10:11 AM
CentralVA.
BBCoronet Offline OP
CentralVA.
Need some pix of the rear sway bar setup in 71 - 74 B bodies. Found a rear with the bar still attached but its not in the car. Any help would be greatly appreciated........
Re: 71 up B body rear sway bar ? [Re: BBCoronet] #670277
04/15/10 10:36 AM
04/15/10 10:36 AM
SF Bay Area, CA
charger440sixpak Offline
SF Bay Area, CA
From the '72 parts manual -
Re: 71 up B body rear sway bar ? [Re: charger440sixpak] #670278
04/15/10 03:57 PM
04/15/10 03:57 PM
CentralVA.
CentralVA.
Thanks Charger but I was kindof hoping for some closeup pix.....From what I see in your pic the bar has dip in it where it goes past the pumpkin....The one I found, I blieve is straight??? Might be for a C body car.....Is the mounting hardware the same or ??? Anyone have some closeup pix???
Re: 71 up B body rear sway bar ? [Re: BBCoronet] #670279
04/15/10 06:17 PM
04/15/10 06:17 PM
SF Bay Area, CA
SF Bay Area, CA
This is the hard-to-find '72 bar with the bends to clear the Dana 9.75" beast...
Re: 71 up B body rear sway bar ? [Re: charger440sixpak] #670280
04/15/10 06:20 PM
04/15/10 06:20 PM
SF Bay Area, CA
SF Bay Area, CA
The straight bar was used on the smaller ones.
Re: 71 up B body rear sway bar ? [Re: charger440sixpak] #670281
04/15/10 07:09 PM
04/15/10 07:09 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
mines looks right in the middle of both... I can't find the pic right now
Re: 71 up B body rear sway bar ? [Re: NachoRT74] #670282
04/15/10 07:14 PM
04/15/10 07:14 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
found it
my rear sway bar rear view
got it NOS and PN was according with my 74 parts catalog
Re: 71 up B body rear sway bar ? [Re: NachoRT74] #670283
04/15/10 08:19 PM
04/15/10 08:19 PM
CentralVA.
CentralVA.
Thanks for the PIX guys...... Now would it be possible to get some demensions...PLEASE!! If it turns out to be a C body bar...Should I grab it anyway or at least get the brackets....Will any of it work on a B body? Thanks Again!!
Re: 71 up B body rear sway bar ? [Re: BBCoronet] #670284
04/15/10 09:44 PM
04/15/10 09:44 PM
SF Bay Area, CA
SF Bay Area, CA
I can't say whether a C-body setup would work on a B-body but I'd guess the brackets are probably all the same. In any case, here's the width of the bar Nacho has, 44".
Re: 71 up B body rear sway bar ? [Re: charger440sixpak] #670285
04/15/10 09:52 PM
04/15/10 09:52 PM
SF Bay Area, CA
SF Bay Area, CA
The shaft links for the B-bodies look like this-
Re: 71 up B body rear sway bar ? [Re: BBCoronet] #670286
04/15/10 10:00 PM
04/15/10 10:00 PM
Kentucky
dfsmopars Offline
dfsmopars  Offline
Kentucky
I put a straight one on my '72 this Winter. It came from a '73. It is really close to the front of the case on my 8 1/4". Even though the rear end in my car is small I'd still like to have a little more clearance with the curved one. I dont' think I can add anything that hasn't already been posted but if I can help let me know.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
