Re: Help! Magnum/nonMagnum block diffs?
[Re: Dusted_Ya]
#670001
04/15/10 12:37 AM
04/15/10 12:37 AM
Posts: 3,905 Oregon
hooziewhatsit
LA blocks oil the head through the mating surface.
Magnum blocks oil the rockers through the pushrods.
To put a non-mag head on a mag engine you need to get oil through lifters and pushrods, and make sure the top end is compatible with them.
[Re: Dusted_Ya]
#670003
04/15/10 08:35 AM
04/15/10 08:35 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
you either need to plumb the heads externally like the indy big block heads do, or drill the #2 and #4 cam jounrals for the oil passages to the deck, run a cam with the oil holes (or cut a groove into the #2 and #4 journals in the cam), and run LA cam bearings.
LA headers will work with magnum heads. they have bigger valves than LA 360 heads, better port velocity & flow, as well as smaller combustion chambers, for a ~.7:1 compression boost over LA 360 heads.
[Re: Dusted_Ya]
#670006
04/15/10 09:04 AM
04/15/10 09:04 AM
Posts: 1,822 Colorado
denfireguy
Colorado
The magnum also has the clearance needed to use roller rockers. Everything you need for the conversion is located here: http://www.mopartsracing.com/parts/a.htmlHalf way down the page you will see: Magnum Cylinder Head Conversion Components Designed to allow the use of Magnum engine heads on pre-1992 Small Blocks. Requires the use of Magnum cylinder heads, hydraulic pushrods, Jeep tappets, and eight Magnum engine rocker arms (P4876050) to oil rocker arms through tappet and pushrod. P5007477 Hydraulic Pushrods — 7.625", Set of 16 (1967–91 Small Block) 37.95 P4529220AB Hydraulic Tappet — Sold Individually (Small Block) 10.75 P4876050 Rocker Arm Set — Single Cylinder (5.9L Magnum, Magnum Crate Engines; Does Not Fit 4.7L) Hope this answers your questions. The tech thread would have the same answers. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: buildanother]
#670007
04/15/10 09:05 AM
04/15/10 09:05 AM
Posts: 2,158 Hamilton,Ohio
POZEST
Hamilton,Ohio
Also worth noting, is that some headers will not clear the magnum mid-block motor mount lugs, drivers side I believe.
This is true but it will fit headers after you touch it up with a angle grinder.
[Re: scratchnfotraction]
#670009
04/15/10 10:25 AM
04/15/10 10:25 AM
Posts: 15,487 Florida
scratchnfotraction
mag has a slightly thiner part of rod at piston and balanced just a little diff some are drilled for LA style head only(early mags) they use a short nose roller cam under the serp t-cover has mag mounts on the middle of block sides fly wheel are slight diff also intake bolts on the mag heads are diff than LA heads you can mix match to make a hybrid roller cam non mag engine mags have short PR and diff rockers 1.6 non adjustables you can get eq heads with mag head and LA style intake bolts cheap for them now days also 318 mag now has the same rear main seal pan as a 360 does across the board and use a 1 piece oil pan gasket IIRC maybe that help OP of this post on his ?s
