Radiator support numbers #66994
06/02/08 11:39 PM
06/02/08 11:39 PM
Anonymous OP
Anonymous OP
I've got a 68 Charger R/T on which I'm doing a little cosmetic work in the engine bay. On the radiator support, there is the code B8X069751 stamped into the metal. I know the 069751 is the sales order number but any significance to the B8X?
Re: Radiator support numbers #66995
06/02/08 11:42 PM
06/02/08 11:42 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
B= Hamtramck Assembly Plant
8= 1968
X= Body Line (Charger)
Re: Radiator support numbers #66996
06/02/08 11:44 PM
06/02/08 11:44 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
B is the assembly plant - Hamtramck
8 is the last digit of the model year - 1968
X may be Charger, but I do not remember for sure?
Edit;
John got off the line quicker.
Re: Radiator support numbers [Re: Alaskan_TA] #66997
06/02/08 11:55 PM
06/02/08 11:55 PM
Anonymous OP
Anonymous OP
Thanks for the clarification. One other question: the coil bracket has a noise suppressor that is wired to the coil. The wire finally broke. Is this factory or should I blow it off? I suppose I could get a generic suppressor from any parts store.
Re: Radiator support numbers #66998
06/03/08 12:29 AM
06/03/08 12:29 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
That sounds like the supressor for your radio.
