Seal expander additives? #669880
04/14/10 07:46 PM
04/14/10 07:46 PM
In a town not near you.
clownzilla Offline OP
Does anyone make decent seal expander additives for transmission radial seal leaks?
My input shaft on my A-833 is leaking past the radial seal which is brand new.
My bearing retainer is brand new but the input shaft has a dip worn into it from years of use of the old seal rubbing into the shaft.
Is there anything I can buy like a helper sleeve to put over the shaft or has anyone had any luck with seal expanding additives?
The early bird gets the worm, and the second mouse always gets the cheese.
Re: Seal expander additives? [Re: clownzilla] #669881
04/14/10 09:04 PM
04/14/10 09:04 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Call Micro Sleeve, they are located in Arlington, TX. they will give you a distributor name. Google for their number or site.
Do Not use any seal swellers waste of $$$$ won't fix anything
Re: Seal expander additives? [Re: roadhazard] #669882
04/15/10 07:55 AM
04/15/10 07:55 AM
Thanks r/h.
