Post deleted by moparts #669868
04/14/10 07:34 PM
04/14/10 07:34 PM
Anonymous OP
Anonymous OP
Re: 72 drums to 75 discs. what do i need #669869
04/14/10 08:26 PM
04/14/10 08:26 PM
BDW Offline
BDW  Offline
Post deleted by moparts [Re: BDW] #669870
04/14/10 09:35 PM
04/14/10 09:35 PM
Anonymous OP
Anonymous OP
Re: 72 drums to 75 discs. what do i need #669871
04/14/10 09:37 PM
04/14/10 09:37 PM
BDW Offline
BDW  Offline
What to do if your car doesn't have a power booster? Simple. Forget it! Unless you have a 5,000-pound wagon, you'll do just fine without it. You can tailor the pedal pressure to your liking by playing with master cylinder diameters. Smaller cylinder = less pedal pressure required. Larger cylinder = ”harder” pedal, less travel. In any case, if you are either staying with, or swapping to, a manual cylinder, be sure that the unit you use has the machined recess in the back of the piston for the rubber pedal-pushrod retaining ring. Most rebuilt master cylinders we've inspected all have this recess. Then, reinstall the pushrod salvaged from your original (drum) cylinder, with a new rubber retaining ring (Mopar p/n 2074960, discontinued, but they are usually supplied with most rebuilt master cylinders).
Re: 72 drums to 75 discs. what do i need #669872
04/14/10 10:36 PM
04/14/10 10:36 PM
uca's, spindles, rotors, caliper adapters, hoses, dust shields, bearings, large bolts. EDIT cant get it straight in my head if 73-76 DRUM uca's use large or small ball joints so just compare your 72's to the 75's and you know in 2 seconds if you need the 75 uca's. I'm wondering about this on a deal here if the uca cams and tbars are untouched will the alignment still be good (the same) going from drum to disc.MORE EDIT if no sway bar issues put the calipers/spindles on the same side as you removed them so your hoses will fit & make for a much easier swap.
Post deleted by moparts [Re: RapidRobert] #669873
04/15/10 04:00 AM
04/15/10 04:00 AM
Anonymous OP
Anonymous OP
Re: 72 drums to 75 discs. what do i need #669874
04/15/10 04:36 AM
04/15/10 04:36 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The 73 and later A body cars with 10 inch front drum brakes use a different knuckle than the 9 inch. The Disc brake UCA uses the larger ball joint, as does the 10 inch drum knuckle.
I have run several A body cars with the 73-76 disc setup, all without the power booster.
Re: 72 drums to 75 discs. what do i need [Re: Kern Dog] #669875
04/15/10 09:48 AM
04/15/10 09:48 AM
Franken does the 73-76 9" drum spindle use large or small upper ball joint?
Re: 72 drums to 75 discs. what do i need [Re: RapidRobert] #669876
04/15/10 12:08 PM
04/15/10 12:08 PM
Atlanta GA
spank04 Offline
super gas
spank04  Offline
super gas
Atlanta GA
the 9" has the small upper
48 imperial limo Woodward cruiser 69-71 60 val wgn 65 val ute 69 aussie val wgn 78 stepside 60 savoy 4dr 84 lebaron ragtop
Re: 72 drums to 75 discs. what do i need [Re: RapidRobert] #669877
04/15/10 06:43 PM
04/15/10 06:43 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
As above, the 9 inch knuckle does use the smaller upper ball joint. It makes no sense to me that Mopar would have had 3 different front brake designs on the same vehicle at the same time. It would have much cheaper to just equip all models with discs. AR Engineering offers a kit to mount 4 piston 2nd gen VIPER aluminum calipers to the 10 inch knuckle... might be worth a look....
Re: 72 drums to 75 discs. what do i need [Re: spank04] #669878
04/15/10 07:31 PM
04/15/10 07:31 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
9" front drums were not available for '73-6. For '73-6 there were only 10" front drums or front discs and they both used the larger ball joints
Re: 72 drums to 75 discs. what do i need [Re: 446acuda] #669879
04/15/10 09:05 PM
04/15/10 09:05 PM
I'm gonna print it out. Thanks guys
