Best way to tighten a crank bolt without air tools #669666
04/14/10 03:13 PM
04/14/10 03:13 PM
Cochise County Arizona
SPWC Offline OP
SPWC  Offline OP
So I rented a Harmonic Balancer install tool and it went back on with no trouble,easy as can be . Now I have got to torque the Bolt that holds it on (3/4-16)
I dont have access to air tools and I have tried to wedge something in between some longer bolts I had threaded into the balancer where the pulley bolts to.
The bolts keep bending. I want to get this over with and torqued to the proper specs. How can I do this when my bolts keep bending and I have no access to air tools?
Re: Best way to tighten a crank bolt without air tools [Re: SPWC] #669667
04/14/10 03:21 PM
04/14/10 03:21 PM
Surface of the Sun, AZ
Hotwheelsjr Offline
Hotwheelsjr  Offline
Wedge a screw driver or something similar between the teeth on your torque converter (or flywheel) and the tranny bell housing. That will keep the motor from turning over while you torque the crank bolt. If the motor is out of the car, feeding rope (clothes line) into a cylinder through a plug hole will provide a cushioned stop and keep the piston from traveling to TDC thus preventing the motor from turning any further.
Re: Best way to tighten a crank bolt without air tools [Re: Hotwheelsjr] #669668
04/14/10 03:50 PM
04/14/10 03:50 PM
scratchnfotraction Offline
the rope in cyl is fastest in the car too
use the other side to brak it loose
if a helper is around screw driver to block edge and teeth on fly wheel or TC
i use the same little diddy for spring swaps with head on engine also
Re: Best way to tighten a crank bolt without air tools [Re: scratchnfotraction] #669669
04/14/10 03:58 PM
04/14/10 03:58 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Before air tools I used a rope too.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Best way to tighten a crank bolt without air tools [Re: SPWC] #669670
04/14/10 04:01 PM
04/14/10 04:01 PM
AndyF Offline
AndyF  Offline
I'm always amazed when people ask this question and nobody provides a link to the tools that are available. Mancini Racing sells a damper holding tool which is inexpensive and easy to use. I also posted a new tool thread just the other day on this board for a crankshaft holding tool.
Re: Best way to tighten a crank bolt without air tools [Re: SPWC] #669671
04/14/10 04:03 PM
04/14/10 04:03 PM
AndyF Offline
AndyF  Offline
Here is a link to the tool thread that I posted a few weeks ago.
https://board.moparts.org/ubbthreads/show...e=0#Post5878114
Re: Best way to tighten a crank bolt without air tools [Re: AndyF] #669672
04/14/10 04:03 PM
04/14/10 04:03 PM
whats a crank shaft holding tool??
I use the dogs rope then tied him back up later when done
Re: Best way to tighten a crank bolt without air tools [Re: SPWC] #669673
04/14/10 04:05 PM
04/14/10 04:05 PM
AndyF Offline
AndyF  Offline
Here is another tool that I make for the same job. This one works with the engine on a dolly or an engine stand. The damper tool works best in the car when you can't get to the flywheel.
Re: Best way to tighten a crank bolt without air tools [Re: AndyF] #669674
04/14/10 04:07 PM
04/14/10 04:07 PM
OOOHHHH!!! thats nice
bad azz dolly wheels too
you seem to make top notch cool stuff there Andy
Re: Best way to tighten a crank bolt without air tools [Re: HealthServices] #669675
04/14/10 04:09 PM
04/14/10 04:09 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Drill 2 holes in a piece of 2 feet long angle iron and bolt it to the balancer. This will give you the leverage you need. Use a stout piece of angle iron.
Re: Best way to tighten a crank bolt without air tools [Re: scratchnfotraction] #669676
04/14/10 04:10 PM
04/14/10 04:10 PM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
I just tightened it with the flexplate on and shoved a screwdriver in one of the holes between it and the block.
Re: Best way to tighten a crank bolt without air tools [Re: AndyF] #669677
04/14/10 04:14 PM
04/14/10 04:14 PM
So Cal
So Cal
Sorry...
http://cgi.ebay.com/ebaymotors/Qty4-15-X...essoriesQ5fGear
and a picture...
Re: Best way to tighten a crank bolt without air tools [Re: HealthServices] #669678
04/14/10 04:15 PM
04/14/10 04:15 PM
So Cal
So Cal
Re: Best way to tighten a crank bolt without air tools [Re: AndyF] #669679
04/14/10 04:25 PM
04/14/10 04:25 PM
SPWC Offline OP
SPWC  Offline OP
That tool looks like it would work well,however,I want to get my truck buttoned up,and am sorta impatient and would have to wait for that tool to arrive.I rarely do any kind of engine teardowns so I would probably use that tool once a year.Id probably end up misplacing it anyway.Ill keep the tool in mind,and maybe suggest it to others.
I did use the rope trick(removed the anchor line off my Jon Boat) and TA-DAH... Worked like a champ!! Tightened to 135 ft/lbs as suggested.
Thanks for the suggestions. Im that much smarter now and will share the rope trick with everyone I know,whether they already know the trick or not!!
Thanks again it worked like a charm!!
Re: Best way to tighten a crank bolt without air tools [Re: SPWC] #669680
04/14/10 04:33 PM
04/14/10 04:33 PM
hooziewhatsit Online content
hooziewhatsit  Online Content
Although I suppose the rope trick only works if you have heads on it
In which case one of the other tools would come in handy
Re: Best way to tighten a crank bolt without air tools [Re: SPWC] #669681
04/14/10 06:22 PM
04/14/10 06:22 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Crowbar.
Stuck in anything that I see turn and if it stops it...
Re: Best way to tighten a crank bolt without air tools [Re: Commando1] #669682
04/14/10 06:37 PM
04/14/10 06:37 PM
Snoopy Offline
Snoopy  Offline
I don't know about anyone else, but I don't feel comfortable introducing possible FOD into my engine. I would rather stick with external remedies.
FOD - Foreign Object Damage
Re: Best way to tighten a crank bolt without air tools [Re: Snoopy] #669683
04/14/10 06:49 PM
04/14/10 06:49 PM
SPWC Offline OP
SPWC  Offline OP
Whats the worse a strand of string can do to an engine if it were to come off the rope.It would probably burn up in the combustion chamber and get spit out the exhaust.
Re: Best way to tighten a crank bolt without air tools [Re: sharpie] #669684
04/14/10 06:58 PM
04/14/10 06:58 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Re: Best way to tighten a crank bolt without air tools [Re: SPWC] #669685
04/14/10 07:41 PM
04/14/10 07:41 PM
Snoopy Offline
Snoopy  Offline
It is what the rope drags into the cylinder, I would be worried about.
How hard is to cut a piece of angle iron and drill two holes in it. You can get the metal for free, just go dumpster diving at any mattress supply store. They throw out all the old steel bed rails.
