Resonator options #669468
04/14/10 08:13 AM
04/14/10 08:13 AM
germany
440sat72 Offline OP
440sat72  Offline OP
germany
I need help finding resonators that will quiet down my 3" TTI x-pipe system with dynomax super turbos. I idle i have a drone that drives me crazy.
I have tried dynomax race bullets as resonators but they do no help (not enough). a friend of mine loves his hushpower resonators, but they seem to be not available in 3" inlet diameter.
what is out there?
car is a 72 satellite, cases should not be too big ...
Re: Resonator options [Re: 440sat72] #669469
04/15/10 05:04 AM
04/15/10 05:04 AM
germany
440sat72 Offline OP
440sat72  Offline OP
germany
Re: Resonator options [Re: 440sat72] #669470
04/15/10 03:03 PM
04/15/10 03:03 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
I heard guys use Magnaflow.........I have the same setup with an 11:1 440 and seems to be ok for me. Although I actually liked the Ultraflows I had on there before.
You running manifolds or something??
Re: Resonator options [Re: 440sat72] #669471
04/15/10 03:40 PM
04/15/10 03:40 PM
Nampa, ID
MadMatt Offline
MadMatt  Offline
Nampa, ID
what is out there?
I just signed on because I was going to post and ask about using Race Bullets as resonators. Sounds like you've been there and done that. Did you get any decrease in noise/drone with them, or was it a total waste? At what point in the system did you mount them?
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: Resonator options [Re: MadMatt] #669472
04/16/10 08:51 AM
04/16/10 08:51 AM
germany
440sat72 Offline OP
440sat72  Offline OP
germany
i welded them in directly after the turndown (?) of the tailpipes behind the axle.
they did create a slight decrease in exhaust tone, but i consider it minimal and am looking for other options.
anyone here has suggestions?
