from a van maybe with the hole for timming marks on the TC
maybe they cut holes and called it that???
look at the cover on the tail shaft to see if its a truck unit it will be on the side..2 screws and cover for the c-clip/snap ring that removes the tail housing
car would be under the tranz mount itself
also might check to see if the center of the tranz mount boss is at 7" from main case
my 78 MH 727 has the mount 2" forward and is 5" from case to center of mount boss
i had to move xmember forward 2" to bolt it in my 88 400 truck build
so I would
first
#s on the drive side pan rail will tell you yr and what its from
good luck on it
