Hopefully, it's a chrome mirror and you can do this without ruining the paint. Soak the whole mirror in a container of lacquer thinner to make the adhesive holding the mirror glass turn loose. Then take the screws out that hold the assembly in. You will see where the solder has come loose on the plate that holds the mirror head tight against the ball. You will have to drill and tap the broken part and use a small screw to hold it tight. Kinda hard to explain, but you will figure it out when you get it apart. I fixed a passenger side Challenger mirror that way, and it works fine now. Good luck.
