Re: BB and SB dist drive gear?
[Re: MonGoo$e]
#669289
04/13/10 10:30 PM
04/13/10 10:30 PM
Posts: 11,543 chicagoland,usa
buildanother
chicagoland,usa
The small block gear itself is flat across the top, as the big block has a raised center.
[Re: MonGoo$e]
#669292
04/13/10 11:43 PM
04/13/10 11:43 PM
RapidRobert
I'd have him pull the pan/oil pump, burnish it then flush/blow it out it out the bottom. You'll be out some more time/trouble but no damage done. He installed it then forgot to check the fit of the inter shaft or if he did he should not have let it go out the door that tight.
