coroded dist. rotor #669162
04/13/10 07:53 PM
04/13/10 07:53 PM
windsor, onatrio canada
metcoll Offline OP
metcoll  Offline OP
would a coroded dist. rotor cause a slow turn over when motor is warm...
Re: coroded dist. rotor [Re: metcoll] #669163
04/13/10 08:09 PM
04/13/10 08:09 PM
no. Always had this prob or recent?. I'd suggest cleaning all of the connections on the large cables starting w the batt positive post all the way around to the neg post. Still bad, borrow another battery to sub in to test it. Starter could be going bad but the easy things 1st.
Re: coroded dist. rotor [Re: RapidRobert] #669164
04/13/10 09:44 PM
04/13/10 09:44 PM
Wpg, Mb, Canada
six-barrel Offline
six-barrel  Offline
Wpg, Mb, Canada
To much initial timing can cause starter drag when the engine is hot.
Re: coroded dist. rotor [Re: six-barrel] #669165
04/13/10 09:49 PM
04/13/10 09:49 PM
