Re: Transmission identification/ OD swap question
[Re: 72scamp01]
#668871
04/13/10 04:33 PM
04/13/10 04:33 PM
Posts: 25,786 Rio Linda, CA
John_Kunkel
Rio Linda, CA
PK52118307 is from a '92-'93 with a 318, it is a 46RH.
The 360 Magnum is externally balanced but it takes different weight(s) than the 360LA.
[Re: 72scamp01]
#668881
04/14/10 04:34 PM
04/14/10 04:34 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Stop thinking RE. The RE trannies had more than three wires since they're computer controlled. All 2 and 3 wire transmissions can be installed without a computer.
[Re: stumpy]
#668882
04/14/10 05:07 PM
04/14/10 05:07 PM
Posts: 11 Owasso, OK
72scamp01
Owasso, OK
360la (408 stroker)stock 93 dakota convertor, B&M flexplate.
you are using a magnum 318 converter? Does the B&M flex plate have the wieghts?
[Re: feets]
#668883
04/14/10 05:11 PM
04/14/10 05:11 PM
72scamp01
Owasso, OK
OK. I haven't been able to find a whole lot of information about it all. everyone just refers to A518 and doesn't specify RE or RH. I was under the assumption that all 46RH were a 2 wire and the RE's were the 3 wire because they were lockup. Looking for clarification because I don't like trusting just one page that I read online and things that I have read aren't lining up with one another.
[Re: 72scamp01]
#668884
04/14/10 05:29 PM
04/14/10 05:29 PM
72scamp01
Owasso, OK
I found the flex plate on B&M website. B&M part number 10236? Are the factory magnum converters neutral balanced? I have the convertors for the transmissions just don't have the flex plates.
[Re: 72scamp01]
#668885
04/14/10 05:29 PM
04/14/10 05:29 PM
Posts: 251 Lithonia, Ga
36PLYM
Lithonia, Ga
I have the 46RH behind a 71 318. Used the two pressure switches with the vacuum switch. Get a copy of Chrysler Performance Upgrades, by Frank Adkins. Lots of great information about the swap and torque converters.
36 Plymouth Coupe 318 w/360 heads 518 trans 8 3/4 rear Ga. Tech BCE'78
[Re: 36PLYM]
#668886
04/14/10 05:42 PM
04/14/10 05:42 PM
72scamp01
Owasso, OK
Thanks I will look it up.
