good sticky 15" tires?
#668818
04/13/10 02:27 PM
04/13/10 02:27 PM
Posts: 401 Berlin, Germany
Flo
Berlin, Germany
Hi, I am looking for a new set of tires for my cough... 79 Firebird... cough. The car is putting around 400 hp at the wheels. For several reasons I cannot leave 15". I want this thing to handle and brake as good as possible
-15" -235 to 255 wide (needs to go on a 15x8" wheel) -aspect ratio between 50 and 60 -needs to be street legal -speed rating at least H, better V -Very important is dry and wet BRAKING and HANDLING. -I do not care AT ALL about snow or "M&S" rating, I am looking for a summer tire -I do not care AT ALL about wear. If the tires are shot after 10000 or 15000 mls that is totally fine.
Is there anything like that around? The closest I could find were Yokohama Y352, but I cannot find anyone in the US who can sell me some of those.
Firestone Firehawk Indy500 seems to be OK (read other post), but they only have an "S" rating. This car will very likely end up on the Autobahn by the end of this year. Any ideas?
I am Ok with paying some extra for extra wishes.
Greets Flo
1967 Fury III 4door HT
tiny 318, late model roller block, bored and stroked to 344
Re: good sticky road street 15" tires?
[Re: Neil]
#668820
04/14/10 05:57 AM
04/14/10 05:57 AM
Flo
Berlin, Germany
Hoosier stopped their street tire line unfortunately...
[Re: Flo]
#668823
04/14/10 03:21 PM
04/14/10 03:21 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
I had 275/50R15 all the way around on the 15 x 8 Snow flakes back in the day when I used to autocross the car but, like the others mention there is not the selection there used to be.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: HealthServices]
#668824
04/15/10 08:43 AM
04/15/10 08:43 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
[Re: patrick]
#668825
04/16/10 09:51 AM
04/16/10 09:51 AM
Flo
Berlin, Germany
The Pirelli actually seems to be a very good fit. A little smaller than I would like and not exactly cheap but far better than anything else I found yet!
Any one here driving BF Goodrich Drag radials on the street? I have no idea how stiff the side walls are on thse, I would think they are fairly flexible and so are unsuited to what I want?
Thanks Flo
[Re: Flo]
#668826
04/16/10 11:53 AM
04/16/10 11:53 AM
Posts: 3,533 Indiana
Fury Fan
Indiana
I think BFG drag radials are a bad idea for any street driving beyond going to the track and back, and the RWD tires might not even be designed as a steer tire. The dedicated FWD sizes probably have a design modifiedfor steering. I'm not a tire expert, but I can't see how a tire designed as a street-legal/drag-race compromise would be anything other than dangerous for Autobahn work. Especially if it rained.
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
[Re: Flo]
#668828
04/16/10 12:44 PM
04/16/10 12:44 PM
patrick
Grand Haven, MI
Thanks Flo
if you were looking at those, I'd go hoosier A6 or R6 first, but I wouldn't want to be caught in the rain...
reasonable cost, I think the 225/70 RSA's will be your best bet height wise.
[Re: TC@HP2]
#668830
04/20/10 04:37 AM
04/20/10 04:37 AM
Flo
Berlin, Germany
well, I read it, but some of these tires (for example the Nittos) are not available anymore in 15".
Currently I am unsure if either the AVON CR6 ZZ or the Pirelli P 600 are my best bet. the Avon comes in 10mm wider (245 over 235), which may be negligable.
Several questions remain: -Are the Avons race tires which need plenty of warm up before they grip? Or will they perform well under street conditions?
-the Hoosier A6 are almost a slick. Anyone run them in the rain?
-is there a Mickey T which would make a good handling street tire? I am Ok with just 10k mls thread life, but whicha re fine for cornering and braking without warming up?
Greets Flo
[Re: Flo]
#668831
04/20/10 01:34 PM
04/20/10 01:34 PM
DaytonaTurbo
Manitoba, Canada
Greets Flo
I think the only MT tire that might be any decent for you is their sportsman s/r. But I'm just going to guess and say they're geared more toward straightline performance than curves, but their tread design looks decent.
Re: good sticky 15" tires?
[Re: Alikazam]
#668834
05/01/10 11:24 PM
05/01/10 11:24 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Dunno about Pirelli's myself. I had a set of PZero's come apart on my during a high speed run in the desert in 87, been gun shy of them since. Kinda scary going backwards at 70+ and trying to steer it away from the shoulder.
[Re: DaytonaTurbo]
#668835
05/19/10 04:19 PM
05/19/10 04:19 PM
Posts: 5,392 Pikes Peak Country
TC@HP2
Pikes Peak Country
Nah, the S/R is designed for corners, unlike their ETs which are best for straight line. They also make the S/T series, which is comparable to BFG TA, S or T rated with small block white letters and an all weather tread.
Don't forget there is also the Mickey Thompson I series which is a 4 ply sidewall and tread face based on early 70s road race tires. They are only available at Summit these days and only come in alpha-numeric sizes, so you'll have to figure out what an L60 and N50 are.
Flo, if what you want is a tire that grips without any warm up, then your going to limit yourself to the A6. Any other tire is going to need a little bit of heat to make things sticky. How much grip do you think you need on a cold tire?
