are these belts okay? #66881
06/02/08 07:22 PM
06/02/08 07:22 PM
ILL
mark7171 Offline OP
mark7171  Offline OP
ILL
i ran then both accross the crank and water pump. only adding one new accessory to each.
it seems to be fine not throwing belts , alt is charging okay,.
is it fine?
Re: are these belts okay? [Re: mark7171] #66882
06/02/08 09:42 PM
06/02/08 09:42 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
except for the power steering belt is not even close to running straight
