Brake and clutch pedal pad install E-body? Any tips? #668809
04/13/10 01:00 PM
04/13/10 01:00 PM
KS
MoparKansas Offline OP
KS
I wrestled with my clutch pedal pad and clutch pedal for probably 20 minutes last night. I tried a litle soap and water and the othe side kept slipping off. Seems like it is like fitting a twenty gallon head in a a ten gallon hat. Are the reproduction pads the right size? Any tips for getting these things on easily?
Re: Brake and clutch pedal pad install E-body? Any tips? [Re: MoparKansas] #668810
04/13/10 02:17 PM
04/13/10 02:17 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I use WD 40 and a thin plastic bar or screw driver to pry the lip up and around the pedal flange. I really haven't had any issue. I did my 73 Challenger stick with after market pads,no problem. I should add that there are early and late peddle pads that are different in shape. I can't remember the year but some are square and some have tapered corners.
Doug
Re: Brake and clutch pedal pad install E-body? Any tips? [Re: dvw] #668811
04/13/10 04:55 PM
04/13/10 04:55 PM
Compare it to the old one but in all likelyhood it's correct, they just go on REAL tight when new and might grab a helper and have them hold one corner engaged as you open up/fit the rest of it.
Re: Brake and clutch pedal pad install E-body? Any tips? [Re: RapidRobert] #668812
04/13/10 05:35 PM
04/13/10 05:35 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Throw them into some hot water for a couple of minutes and then try putting them on.
