Torque thrust for 67 Dart #668770
04/13/10 11:36 AM
04/13/10 11:36 AM
moparkc Offline OP
moparkc  Offline OP
I found a set of CHROME TORQ THRUST WHEELS wheels that I would like to put on my pretty much stock ‘67 Dart. The only change from the stock suspension setup is that I have put ‘73 disc brakes on the front. The wheels are 15x7 for the front and 15x10 with 3” back spacing for the rear. Does anyone know if they will fit? If the wheels do fit, does anyone know how wide of a tire I can put on the back that will fit inside the wheel well with no modifications? Thanks for any and all input.
Re: Torque thrust for 67 Dart [Re: moparkc] #668771
04/13/10 11:55 AM
04/13/10 11:55 AM
Houston, Texas
racerx20 Offline
Standard but OK
racerx20  Offline
Standard but OK
Houston, Texas
I think your going to run into a issue with the rear wheels. I am running a 245/60/15 in the rear on 15X7's w/5" of backspacing on my 69 and there isn't much room left. You maybe able to squeeze a 15X8 by tweaking the backspacing etc but it'll be tight. Anything bigger is going to require a spring relocation and or mini tub
1972 Road Runner
1988 Shelby CSX-T
Re: Torque thrust for 67 Dart [Re: racerx20] #668772
04/13/10 12:05 PM
04/13/10 12:05 PM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
10's will never fit w/out moving the leafs inward.
I have 245/60/15's on 15 x 7" w/4.5" b/s and there is a little more than a finger to the spring n wheel lip. Stock spring location but w/11 x 2" brakes w/axles to account for the wider brakes. Bumped the axle flange out 3/4".
Re: Torque thrust for 67 Dart [Re: racerx20] #668773
04/13/10 12:06 PM
04/13/10 12:06 PM
moparkc Offline OP
moparkc  Offline OP
I was afraid of this. Any thoughts on using a spacer? Guessing if I did use a spacer I would be pushing the rim out so far that the tire would hit on the fender. Oh well........ thanks for reply
