833 overdrive conversion #668729
04/13/10 10:44 AM
04/13/10 10:44 AM
Central Ohio
Ledman_70 Offline OP
Central Ohio
OK, I'm ready to put my 833 OD behind the 426 wedge my my 64 Polara, so I'm just double checking one more time...what I need is a bigblock truck bellhousing, right? Any specific year/part number, or will any of them work? Are there any other mods or parts I need to perform this swap? Car is currently 833 with small register bh, so I don't want to open this one up. If anybody has a bh they'd like to sell let me know. Thanks guys.
Jeff Adams 64 426 Polara
Re: 833 overdrive conversion [Re: Ledman_70] #668730
04/13/10 10:51 AM
04/13/10 10:51 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Machine the bearing retainer on a lathe to fit a '68 and newer (large bore) passenger car bellhousing.
Re: 833 overdrive conversion [Re: DoctorDiff] #668731
04/13/10 11:02 AM
04/13/10 11:02 AM
Central Ohio
Central Ohio
Didn't think of that Doc...car bh probably easier and cheaper to find than truck. Thanks
Re: 833 overdrive conversion [Re: Ledman_70] #668732
04/13/10 12:16 PM
04/13/10 12:16 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
You need to use 10.5" bellhousing in a 64 for stock clutch linkage parts to work.
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: 833 overdrive conversion [Re: 64dodge572] #668733
04/13/10 01:46 PM
04/13/10 01:46 PM
Central Ohio
Central Ohio
Car has a 65 bh right now and I had to extend the lower arm a little to reach the fork. Are all the later bh 11", or did they still make the 10.5 into the 70's?
Re: 833 overdrive conversion [Re: Ledman_70] #668734
04/13/10 02:11 PM
04/13/10 02:11 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
If you had to extend the z-bar arm, the fork pivot bracket inside the bellhousing is wrong. Use the bell you have.
FAX 937-947-4419
