Amps dance with the headlights on
#668678
04/13/10 10:19 AM
04/13/10 10:19 AM
Posts: 802 Houston, Texas
racerx20
Standard but OK
Standard but OK
Houston, Texas
On my 69 Dart I have noticed that when I am cruising down the road with my headlights on my amp gauge will jump quickly from charge to discharge repeatedly. The headlights/dashlights will also dim/brighten in sink with the gauge when this happens.
I know the headlights dim when idling with the headlights on but not sure why it's jumping around while cruising. It seems to act normal while idling with the lights on. I was contemplating installing a new voltage regualtor and a headlight switch(the dimmer is messed up on the original switch).
Everything is great when the sun is out it just acts up with the headlights on. Anyone have any other ideas of what is happening? Thanks
1972 Road Runner
1988 Shelby CSX-T
Re: Amps dance with the headlights on
[Re: racerx20]
#668680
04/13/10 10:25 AM
04/13/10 10:25 AM
RapidRobert
I'd get a new ELECTRONIC VR (wells vr706, maybe 607?) or if oe appearance is desired a guy here has one w a black cover $25 to your door and I'd pull the alt brushes & check them real quick but most likely the VR. you mean the dash lights dimmer rheostat thats part of the headlight sw or the hi/lo beam dimmer sw?
[Re: RapidRobert]
#668681
04/13/10 10:44 AM
04/13/10 10:44 AM
racerx20
Standard but OK
Standard but OK
Houston, Texas
I will start with the connections. Do you guys know the name of the person selling the factory appearing electronic regulators? RapidRobert- I meant the dash light dimmer that is part of the headlight switch. Sometimes I have to jiggle it to get the dashlights on. Thanks for the tips
1972 Road Runner
1988 Shelby CSX-T
[Re: racerx20]
#668683
04/13/10 05:37 PM
04/13/10 05:37 PM
RapidRobert
The guy selling them I cant recall his name but his ad is I think the A body parts for sale but not for sure but it's there somewhere. Might take the h lite sw out & check the rheostat coil and make sure the arm that makes contact along the coils that it (& the coils) are bright/shiny and the arm has enough constant tension to bear on the coils as you rotate it on around
[Re: RapidRobert]
#668684
04/13/10 08:18 PM
04/13/10 08:18 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
It's your mechanical regulator clicking on and off. Either adjust it, procedure is in the FSM, or get the electronic guts version.
My 65 Cuda does it a bit and it's NOT grounds, lack of relays or dirty connections. It's the mechanical regulator.
