Torsion Bars #668627
04/13/10 07:54 AM
04/13/10 07:54 AM
64MAX Offline OP
64MAX  Offline OP
Do you guys use a special grease on the ends of the torsion bars when you install them? Thanks for the help.
Re: Torsion Bars [Re: 64MAX] #668628
04/13/10 09:58 AM
04/13/10 09:58 AM
I use the grease gun that has a tube of high quality wheel bearing grease that I use for wb's/ujoints/front end. fast and convenient EDIT it might work to add a boot on the back side to keep grit out of there
