Monitoring fuel pressure during run #668611
04/13/10 03:21 AM
04/13/10 03:21 AM
Oregon City, OR
Baxter61 Offline OP
Baxter61  Offline OP
Oregon City, OR
Do you guys have a way to monitor your fuel pressure during a run? or do you just run the guage by the carb and call it good? if you do, whats your setup? where do you put your guage? Im semi looking for a kit or what you used to piece your setup together. thanks!
Re: Monitoring fuel pressure during run [Re: Baxter61] #668612
04/13/10 03:41 AM
04/13/10 03:41 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i have a fuel pressure guage mounted on my cowl. easy to see if i've forgotten to turn the pump on when the guage is in your face. i also have one channel of the logger recording the pressure. normally after the brake is released the pressure drops from 9psi to 7psi. when it dropped to 5 we found the filter was becoming blocked from dirty fuel. if you can't afford a logger at least put a guage on the cowl in your face. it gives you something to look at if your engine starts to misfire at speed. helps eliminate potential causes.
Re: Monitoring fuel pressure during run [Re: rebel] #668613
04/13/10 06:57 AM
04/13/10 06:57 AM
madison, ohio
modified1090 Offline
madison, ohio
same here!
Re: Monitoring fuel pressure during run [Re: rebel] #668614
04/13/10 08:14 AM
04/13/10 08:14 AM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
what gauge do you use to log psi by converting it to volts? i have a LM-1 and a LC-1?
i use a camera to look at on the gauge incase i dont look at them.
Re: Monitoring fuel pressure during run [Re: Baxter61] #668615
04/13/10 10:47 AM
04/13/10 10:47 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Data logger and a isolated gauge that sits in front
of me
Re: Monitoring fuel pressure during run [Re: blownzoom440] #668616
04/13/10 02:41 PM
04/13/10 02:41 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
guage is mechanical & logger is a sensor in the fuel line by the carb.
Re: Monitoring fuel pressure during run [Re: rebel] #668617
04/13/10 02:49 PM
04/13/10 02:49 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
I have the gauge mounted in front of me inside the car. It uses an isolator with the fuel going to it and then antifreeze from the isolator to the gauge.
Re: Monitoring fuel pressure during run [Re: blownzoom440] #668618
04/13/10 06:04 PM
04/13/10 06:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You use a pressure transducer... most are set up for
a 1-5 volt span
Re: Monitoring fuel pressure during run [Re: rebel] #668619
04/14/10 06:31 AM
04/14/10 06:31 AM
New Zealand
nz383man Offline
nz383man  Offline
New Zealand
Is that sensor available in NZ?
After the issues I've had I'd like to log the fuel pressure on my LM2
Re: Monitoring fuel pressure during run [Re: Baxter61] #668620
04/14/10 07:45 AM
04/14/10 07:45 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
like most here all the gauges are in my face...
