64 manual steering box interchange question
#668509
04/12/10 08:38 PM
04/12/10 08:38 PM
Posts: 12,085 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I have found a 64 Dart 4 door with a 273 and a manual steering box. How new an A body will that box fit? Will it fit a 70? Thanks!
Master, again and still
Re: 64 manual steering box interchange question
[Re: DaveRS23]
#668510
04/12/10 09:42 PM
04/12/10 09:42 PM
RapidRobert
All A body manual boxes will interchange for you (even up to 76)
[Re: RapidRobert]
#668511
04/12/10 10:20 PM
04/12/10 10:20 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
That is very good news. Thanks!
[Re: DaveRS23]
#668512
04/13/10 01:18 PM
04/13/10 01:18 PM
Posts: 1,443 Maryland
Dads426
Maryland
If you are converting from power steering you will need a longer steering column or a steering adapter (Mancini sells them).
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: Dads426]
#668513
04/13/10 04:44 PM
04/13/10 04:44 PM
RapidRobert
FYI the inner shafts from 63-66 A body steering columns interchange so if your col is nice and you want to keep the color you can pirate one to go from man to power or vice versa, Take the whole col out and the external snap ring at the top is the most difficult part. Way less parts/pieces to deal with than the 67 up columns
[Re: RapidRobert]
#668514
04/13/10 08:11 PM
04/13/10 08:11 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
More good info, thanks guys!
