Thunder series 800? #668328
04/12/10 06:19 PM
04/12/10 06:19 PM
Branson, Mo.
joedust451 Offline OP
super gas
super gas
Branson, Mo.
Is there any out there running one on a SB, how do you like it? I'm thinking maybe i'll give this carb a try on my magnum 360.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Thunder series 800? [Re: joedust451] #668329
04/12/10 07:07 PM
04/12/10 07:07 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
I have one on my Big block. Runs super. Very snappy. Easy to tune.
Re: Thunder series 800? [Re: Dougsmopars] #668330
04/12/10 07:10 PM
04/12/10 07:10 PM
dulcich Offline
dulcich  Offline
I have one on my 340 in my 71 Satelite. Works very well.
Re: Thunder series 800? [Re: joedust451] #668331
04/12/10 07:27 PM
04/12/10 07:27 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
The thunder AVS are great. the 800 works nice with a 440. Much better effort than the "street avenger" series by holley.
Their operation is very easy to tune. If you have the right sized carb, it works.
With a 3.73 gear, perf exh manifolds, and summit 1103 cam, action + manifold, the 650 AVS ran the quarter in the low 14's. In a GM 350" V8 swapped buick skyhawk.
Re: Thunder series 800? [Re: mark7171] #668332
04/12/10 09:57 PM
04/12/10 09:57 PM
Branson, Mo.
super gas
super gas
Branson, Mo.
This will be for my 360 magnum in my dart, so in a nut shell, its a better carb then the 750 AFB Eddy?
Re: Thunder series 800? [Re: joedust451] #668333
04/12/10 10:14 PM
04/12/10 10:14 PM
Dougsmopars Offline
Dougsmopars  Offline
The 750 Eddy is nothing but trouble. It's a poorly designed carb. There have been hundreds of posts here with people having trouble with them. The 800 Thunder is a whole different carb.
Re: Thunder series 800? [Re: Dougsmopars] #668334
04/12/10 10:17 PM
04/12/10 10:17 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
The 800 should be fine. The 750- don't get that ball rolling on here again, please.
I want my fair share
Re: Thunder series 800? [Re: SomeCarGuy] #668335
04/12/10 11:09 PM
04/12/10 11:09 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I know someone who has a well used 750 carter afb on a low budget 408 small block mopar and it doesn't miss a beat. I have no idea if the carter is better or different than the edelbrock carb though.
My brother has an 800 eps on a 455 buick and it runs out nice. I wouldn't put one on a stone stock 360, but I think it would work if the engine was modified somewhat.
Re: Thunder series 800? [Re: Neil] #668336
04/13/10 01:02 AM
04/13/10 01:02 AM
Branson, Mo.
super gas
super gas
Branson, Mo.
I just won this 800 AVS, its good to here there decent carbs, the combo is this, i think it'll handle it.
71 Dart MS, MBs, no AC
360 magnum, stock short block. (9.1 comp.)
RHS heads, Re-ground factory roller (.477/.477, .218/.218 @50 with 1.6 rockers)
Summit headers, Air-gap, mallory 6AL, MSD dist.
PTC 2800 11", 904, Cheetah FMVB, 3.73s.
http://cgi.ebay.com/ebaymotors/ws/eBayIS...RK%3AMEWNX%3AIT
Re: Thunder series 800? [Re: joedust451] #668337
04/13/10 08:37 AM
04/13/10 08:37 AM
Dalton, MA
Slipknot440 Offline
Slipknot440  Offline
Dalton, MA
ive got one on my hemi....and I'm not that impressed by it at all
