over torqued magnum intake bolts. Let it go or fix? #66832
06/02/08 05:43 PM
06/02/08 05:43 PM
Andrewh Offline OP
Andrewh  Offline OP
360 magnum, torqued the intake bolts to 25 ft/lbs.
Doesn't seem to be leaking.
Do we take them out and put them back to 12, or just leave well enough alone?
Re: over torqued magnum intake bolts. Let it go or fix? [Re: Andrewh] #66833
06/02/08 07:00 PM
06/02/08 07:00 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Let it go now...12 feels light to me, 25 really is'nt all that bad...I would'nt go looser now...Just remember the torque value next time... I always overtorque different stuff depending on the track record of the piece...If it's a problem child then I adjust my grip accordingly... ...
Re: over torqued magnum intake bolts. Let it go or fix? [Re: Andrewh] #66834
06/02/08 07:57 PM
06/02/08 07:57 PM
Chicago illinois
ChinooK440 Offline
ChinooK440  Offline
Chicago illinois
If it,s not leaking , i,d leave them alone.
Although f.w.i.w. The stock magnum intake bolts are Torque to yield type bolts and aren,t supposed to be reused .
